View Full Version : V6 Tech
- GM V6 vs Ford V6
- Need O2 Sensors!!!
- Bracket Behind Cat?
- Waht Knid Of Free Moods
- 3.4 v6 and tranny for sale,low miles.
- who would like a sweet swap site
- Typical oil pressure 3.4
- instrument swap ???
- need brighter lights!!!!
- HELP! Feels like i'm gonna stall!
- 6 Speed
- Thermostat
- Loud Clicking Sound...
- Was I sent the wrong shifter?!?
- SLP wisper lid
- Upgrading to Super Stock 4,000 converter, my ProYank 3200 is available
- Feel like my mileage has gone to pot lately
- updated list???
- Gear ratio?
- 3.4 jet chip questions
- Owners Manual
- Temp gauge not working
- which wires
- these lil ricer kids
- Engine Swaps
- pulling codes
- fuel filter problem
- HOW DO YOU LAUNCH A 3.4 l CAMARO?
- 97 pcm
- How Can You Spot A V6 From A Z28?
- how much oil in a 3.4l v6 ???
- 94 Camaro 3.4L VS 1990 Honda CRX SI
- 3.4 Wants New Exaust
- strange coolant leak
- HP Progressive Tuner?
- 3.8 Performance MAF's or TB's
- ? 3800 Changes/Improvements 98-02 ?
- Is this normal for a Y87???
- Where is a good place to put a cut-out?
- Overheating Issues with my 3.8L
- high rpm
- Free 3800 V6 engine
- Question about the v6 transmissions
- Gutting my cat
- I have a few questions so im gonna just make one post!
- Oil additives
- Can I install a Cut-Out if I already have an exhaust?
- Weird blower type wining noise.
- my y87 firebird lost to a 1990 lincoln mark vII lsc coupe
- 3.8 Rocker Adjustment
- 95 3.4L water pump install...tips and tricks needed ....w/in
- Where to Find 3.8 Underdrive Pulleys?
- 98 z28 camaro exhaust on 94 3.4L camaro?
- Are these mid-tubes or short-tubes?
- Need some help
- Ever Dyno?
- help....3.4 camaro overheating..w/in
- Springs, shocks, sway bars, etc
- Intake manifold question
- Oklahoma V6'ers!
- Long tube header questions.
- gotta dumb one for ya........
- power windows
- Heard V6 brackets will work on a Small Block 400, True???
- SLP Exhaust
- Water in oil....
- Weird Noises - Any Help
- Another Camaro in the stable
- what will they think of next?!?!
- V6 3.8L Plug Change HOW TO?
- K and N Typhoon intake
- TB Bypass?
- What Kind Of Tires?
- What size is my catalytic cat converter?
- internal coolant leak?
- Smoking/Oil Leak Problems
- Where to buy Carsound cat 23494??
- Catalytic Converter?
- What Is The That Rattle Sound?
- Should I Get Headers?
- wanting electric windows...
- 94 3.4L camaro vs. 92 prelude
- What engine oil are you using?
- Catback or muffler???
- need help
- LT1 vs. LS1
- Me again...forgot to add something....BOG PROBLEM???
- This a Good Induction System?
- Seems like my car bogs when i gun it....HELP PLEASE!!!
- does anyone in here need a 2000 model 3.8???
- Are Camaro V6 front signal lights different then Z28 and SS?
- lt1 tb on a 3.4
- Borla or slp loudmouth
- losing too much water!!
- 3.8 Won't Start!
- 60 degree heads
- some V6s Qs
- 3.8 EGR Parts
- Which is lighter?
- Camaro back from Winter Storage = Problems!
- Will it work?
- Help!! Heater hose leaking!!!
- Catalytic Converters for 3.8 v6
- 3.8 liter out of 96 riviera??!!!
- take off cat..good bad?
- stock internals, bolt on only 3800
- 95 3.4 Owners Report ! Need to identify the DLC connector
- How long should I drop my Camaro?
- Can a V8 Eibach Springs fit a V6?
- Trying to keep my 3.4 cool
- 99' Camaro
- shes fixed!
- Is a 1.75 drop too much?
- Borla Exhaust Tip
- Air Conditioning Belt
- Do I need a Camber Kit if I lower my Camaro?
- Are all Catco Cats high flow?
- '94 camaro 3.4L valve gaps?
- Camaro 3.4L valve covers?????
- Another Horsepower question
- spit sputter die
- Can a short stick shifter be installed in my 2001 Camaro V6?
- Ideas on how to make my 2001 Camaro V6 faster?
- What kind of springs should I get?
- 3.8L Camaro Underdrive Pulley?
- A question about dual exhaust sound.
- m5 vs y87
- stock 1/4 mile times and 0-60
- Pros and Cons of EGR Block off
- LS1 brakes?
- American Racing Torq-Thrust II 17 x 9.5
- Performance Chips
- help w/ coil selection please!!!
- Think I have a power steering fluid leak
- Can LT1 exhaust work on a V6 Camaro??
- Cant loosen this bolt
- Stock 97 camaro. What should i do!?
- Sometimes when I turn the key on my car loses all power and clicks.
- Cam and Roller Rockers
- Headers Question
- SES troubles...
- direct fit high flow cat converters??
- Having big problems
- Changing Valve cover gaskets
- Remove Entire Exhaust?
- Alternator???
- 1994 LT1 into a 1995 V6 Camaro
- 4SA Transmission Question
- Rough Idle (3.4L)
- HELP V6 to A V8 K member problems HELP???
- foggy headlights
- HELP 56mm need spacer!
- Turbo v6 Camaro?
- Decided to biuld the V6 with a Stroker...
- headlights
- 3.42 gears
- DRIVESHAFT!!! My 98 Camaro
- who makes underdrive pulleys for a 3.4l
- D 0r Od
- V-8's RULE
- Exhaust Sounds .. clips!
- what not to do to your camaro
- Auburn differential help
- Hella FF75 Help Please
- What do you think of this car?
- Shift Kits?
- New Exhaust for 3800 Series II
- help 95 camaro HVAC problem..hear hissing behind AC controls..w/in
- JET PCM Chip Stage 2 startup?
- 4.3 V6 Bellhousing Pattern?
- cracked box by the horn
- Will these wheels work?
- oil leak or head gasket blown???
- 3.8 questions?
- chips
- 95 3.4 cranks, but won't start
- Engine question.
- Home Tunning?
- newbee
- removing the stock grille?
- converting my 94 3.4L to a 5.7L need help...
- Tires and rims
- limited slip v6?
- 94 3.4l Burnout?
- scratched windshield
- Someone please explain this error code for me?
- 943.4l Oil pressure at zero Help!!!!!!!!!!!!
- My Y87 is sick - I'm clueless
- Whats up?
- PICS - Coolant Leak - Help
- Don't sell your camaro
- Coolant leak - Help!
- GT2 cam for 3800.
- Swapping a F-body 3.4 V6 into a Jeep Cherokee
- Hey Im New
- New kid with over heating problem
- Is This True?
- 2002 v6 3800 leaking?
- Anyone Have MSN?
- hard starting
- free 3800 ram air?
- Is It To Late?
- need 3.8L belt diagram!
- brink's unfortunate events.
- 99 3.8 fuel pump problem
- 95 Camaro 3.4L Idling Problem
- Service Engine Soon light.
- Not able to burnout? 3.8L Auto
- ecu problems
- rear emblem?
- Transmission Suggestions...?
- Foul Smell from Exhaust?
- Exhaust problems / Car
- Cars Whines When I Turn
- my v6 runs rough
- Broken crank???
- Fog Lights
- auto is so much slower then 5 speed
- Few Questions on Gears
- Flomaster Exhaust: Install Article From P.H.R.
- Y87 Package?
- Possibly selling this
- checking ingition module
- Took My Catalic Converter Out
- seeking 4.3 litre v6 knowledgables.
- My camaro is not going past 3000 R.P.M...HELP PLEASE! UPDATE!!!
- 94 v6 3.4 firebirs egr ?s
- Smoldered Yet Another Wire!
- Engine whining sound
- Engine Light is on
- Need a new throttle body...
- 2 questions from a new owner
- High Mileage 1996 V6 Auto, Options?
- if i swap engines, do i have to change my exhaust?
- 1995 3.4L 28k miles.. need help POSSABLE BUYER
- How much for head gasket change? (Labor only)
- New Old Dead 86 Camaro 2.8L
- 1996 camaro 3800 rebuild or z-28 motor??
- Smoldered a wire on the manifold!!!
- few questions on TT'ing a 96 rs
- 1994 v6 to carb
- 3400 to 3800 swap
- 4.3 Vortec Mods
- anybody tried that Metco Valve Cover Breathers
- Complete 3.4 DriveTrain, wireing Harness, AC,Radiator,10-bolt 4sale WNY
- performance chips
- Is my coolent right?
- 1994 v6 to carb 383
- wont start...
