Coolant leak - Help!
Old Feb 22, 2005 | 09:41 PM
Infinity2134's Avatar
I just recently noticed that my camaro is leaking coolant. This only seems to be happening when I park it on an incline. It goes away if I back it into the driveway. It sometimes leaks if its parked flat. What could be the problem and how should I fix it?
Old Feb 22, 2005 | 10:09 PM
Distephano's Avatar
Re: Coolant leak - Help!
It sounds like its leaking while the engine is running and it pools somewhere, so it only runs out when you are parked with the front end pointing one direction.
I'd go take it for a drive, bring it back in the garage, put it right up on the stands or ramps and look for leaks.
Once you find out where the leak is we can help you lots more.
Old Feb 22, 2005 | 10:17 PM
i know that i can see it dropping from whatever plate that runs under the engine.
Old Feb 22, 2005 | 11:11 PM
Distephano's Avatar
The metal plate in front of the Oilpan? That would be the K-Member.
We are talking about a 3.8L engine, right?
Well, either way... There is a ton of things above the K-member that could be leaking.
I assume you have already checked all your hose calmps and connections, right?
Next I'd look at your water pump, is there coolant coming out of the weep hole?
Old Feb 22, 2005 | 11:29 PM
its a 3.4 - ill check that tomorrow.
Old Feb 23, 2005 | 07:31 AM
brink's Avatar
i just had one coming from my intake mandifold gasket that cost me 500$ to fix o.O hope its not that... i was racing a riced out civic on the interstate and got to 120 mph... and the gasket was already leaking (slow leak) and then it made it worse.. but hey, i beat the honda by like 20 cars.. and the leak is fixed and im going to get my car right now..
if u race rice u have to pay the price... but at least you still win
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
