Opti substitute for bbc to keep LT1 pcm
Old Oct 25, 2002 | 08:41 PM
skipnsb's Avatar
Hi. I want to put a mild bbc in my 95 9c1 Caprice. How can I keep my stock pcm (will need to be re programmed of course). This will be a mild build up, no nos or supercharger, bigger injectors of course, max 555 hp so I believe the pcm will handle it, but how do I get the opti signals to the pcm. This will be a daily driver and I would like to keep all the cruise control, etc.
My other option is just bash in the firewall and put a distributor on it.
On the other hand, if I must go to aftermarket, what opinion of using the Holley commander and the four barrell tbi, can I have the stock pcm programmed to handle the cruise control, torque converter lockup, shift, etc. without it having engine sensor input, or can I split the sensor input to both the computers.
Thanks for any help or alternative ideas. skip
Old Oct 28, 2002 | 02:18 PM
Mikael's Avatar
Wow. Dropping in a big block = fun
Figuring out the wiring = no fun.
Best of luck
Old Oct 29, 2002 | 01:23 PM
Mikael's Avatar
I think a company called electromotive makes an SDI system that'll replace the opti with something similar to the LS1's individual coil pack setup.
Alex Barnes
Jan 24, 2015 10:21 PM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
1LEThumper
Jul 14, 2003 12:45 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
