396 questions
Old Nov 5, 2002 | 05:50 AM
hotrod 95's Avatar
396 questions
How much more block clearancing do you need on a 396 versus a 383?
Old Nov 5, 2002 | 07:24 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
If you are referring to main and cam bearings- the specs should stay the same...
most everything stays the same...
Old Nov 5, 2002 | 08:45 AM
cASe SenSiTive's Avatar
Exposed Member
I'm pretty sure he's talking about clearance because of the extra stroke.
You'll have to take a little more material off in some areas. There's not any real way to know for sure until you get it all together and find out where it's close. How much you take off also depends on the parts you're using (i.e. H-beam vs. I-beam, etc.).
Old Nov 6, 2002 | 09:15 AM
Eric Bryant's Avatar
Well, assuming that you use the same rods on each motor, I'd say that a 3.875" stroke takes about 0.0625" more clearance than a 3.75" stroke. What's heavily dependent on the rod is whether this extra 1/16" of an inch will cause problems with the oil pan rail, cylinder base, or camshaft. Needless to say, "profiled" stroker rods are the way to go if you intend to run a standard base circle cam and don't want to run the risk of cutting into the water jacket.
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
