Theory: pushrodless LT1 engine?
Old Sep 26, 2002 | 12:51 PM
gbelli's Avatar
Just wondering about the theory of a pushrodless LTx engine. Obviously the cam would still reside as to drive the oil pump and opti, but removing the pushrods.
You'd be able to actuate the rockers via computer controlled solenoid. This would yield limitless possibilities with the timing of valve events; duration, LSA, etc. Oversimply saying you'd be able to get a gas mileage tune, NA tune, N2O tune, and everywhere in between. Absolutely no sacrificing associated with 'picking the perfect cam' it'd be a near infinate powerband!
Just thinking out loud
Old Sep 26, 2002 | 01:31 PM
Luna's Avatar
Some F1 cars use a similar tech.
Old Sep 26, 2002 | 05:28 PM
BluEyes's Avatar
I belive that also necessitates converting to a 42V (?) system to be able to run solenoids powerful enough to work the valves.
Old Sep 26, 2002 | 05:51 PM
Thomash's Avatar
I thought I saw this on some high end BMWs. I know Ducati is using a Desmonic(sp) valve train on the 998s. No valve springs.
Soma07's Avatar
F1 cars use compressed air to close the valves faster than the spring could. I'm pretty sure this is the primary reason they can turn such incredible RPM's (~19,000 in qualifying trim). I dont know if they still use a cam to open the valves though.
I read a while back that Mercedes is working on the camless engine using electromagnetic soleniods to open and close the valves. However like Blueyes mentioned they think they will need to switch to a 42v electrical system to pull it off.
Alot of people like to talk about the death of the IC engine but I still think there is plenty of life left in them utilizing technologies being developed today. Just think of the possibilities of a motor with displacement on demand, direct injection, and infinately variable valve timing (camless engine).
Old Sep 26, 2002 | 11:12 PM
That would be desmodromic
http://redvolution.ducati.com/eng/motore.html
Old Sep 27, 2002 | 01:50 PM
BluEyes's Avatar
this could be the death knell for the 'performance' engine - they'd all be the same!
Pull huge vacuum at idle, and be able to rev it as high as it will hold together!
Finally, we might have a VTEC V8
oldschool
Feb 9, 2016 09:21 PM
willismoons
Feb 14, 2015 08:42 PM
Jrlt1
Jan 3, 2015 07:38 PM
Jul 4, 2005 05:00 PM
