Camshaft gurus.....need some help pleaze
What is the difference in hp and tqr curves between a split pattern and a single pattern? Reason I am asking is I'm looking at the xe 230/236 or get a custom 230ish single pattern xe cam and was wanting to know if there was a differnce in power between the cams on the same motor. My heads flow very close to 80% so thats why I was wondering.
Thanks,
Jeremy
Thanks,
Jeremy
There's a reason almost all LT1 cams are split: it works better! The relatively efficient intake relative to the exhaust on a 4th gen F-body needs a split to work efficiently. IF you had a set of heads with great exhaust ports and were running something like an open exhaust, you might consider a cam without a split. Otherwise, you should get cam like the 230/236. It will make more power.
Rich Krause
Rich Krause
Originally posted by ToddR
So given a 224/238. 115lsa.
What should the Installed centerline be with only a 68% ratio?
You can tell the amount of advance ground into a cam by comparing the LSA and the intake center line (ICL). When they are the same, there is no ground in advance. My cam, for example, has a 114ICL and a 114LSA. If the cam had 4 degrees of advance ground in the ICL would be 110 degrees.
Rich Krause
Here is a link to an intersting article on the subject:
http://www.iskycams.com/techtips.html#2003
