tranny mounting questions ...
>I hope this goes here
will a turbo 400 , turbo 350 , or 700R mount up to a '94 LT1 engine , and if so what type of adapters are required ? and are the crossmembers the same ('67-69 Camaro) ?
Later ...
stay safe
.will a turbo 400 , turbo 350 , or 700R mount up to a '94 LT1 engine , and if so what type of adapters are required ? and are the crossmembers the same ('67-69 Camaro) ?
Later ...
stay safe
The 700R4 was renamed 4L60 and then 4L60E when the electronics were added.
There are alot of people who use a TH400 tranny so it will bolt up to the block just fine as it's still a small block chevy.
Not sure about the crossmembers.
Marc
Marc
>Thanks Marc ,
I just realized that I included the 700R with the others ... I knew about the 4L60 and 4L60E being a clone of the 700R , but I brain farted during the typing
. The real question was : Is the turbo 350 and 400 the same as the 700R and 4L60(E) 's including the bolt pattern and tranny mount ? I got the permission from "Helga the money ogre" oops I mean wife
that after I finish the '94 I can start on another project
Later ...
stay safe
.Later ...
stay safe
SavageZ28
17
Jul 14, 2002 11:04 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
