HELP GAS IN OIL never seen this b4 on a lt1
i have a 97 trans am with the lt1 engine i bought the car werecked and all the airbox and maf were busted in the wreck ,well i replaced all of that and the car will start and run but it pops misses shakes and black smokes badly then i chaged the oil and relized it has alot of gas in it i new the guy b4 me had the valve covers off and been messing with the valves so i adjusted them correctly and now the car will not even start it will hit and act like it wants to but will not ,i went back and made sure i adjusted them right i got the motor on tdc compression stroke adjusted the 1 cyclinder then turned the crank 90 degress and adjusted the next one in the firing order and keep doing that until i completed it .well anyways to make a long story short the car wouldnt start and so i checked the oil again and its already full of gas again ,so i figured maby i have a ring busted or somthin so i ran a compression test all cyclinders were between 150 and 170 so there all good can anyone tell me what the problem could be ive never seen anything like this on a post so try to help me
Originally posted by 87ROC
r u getting fire? Unburnt fuel could be seaping(spelling) past the rings maybe.
Did the wreck involve a roll-over? If so, the EEC canister may be saturated with fuel, and you are pulling raw fuel into the intake when the purge operates.... or the purge may even be stuck open.
Also, check the fuel pressure regulator for a ruptured diaphragm.... that will feed raw fuel into the intake manifold.
Check the fuel pressure... accident may have damaged the fuel pressure regulator, or the fuel return line could be crimped, giving you excessive fuel rail pressure.
Suggestion - when you buy a car, even one that hasn't been in a wreck, change the oil BEFORE you do anything else......
car started
ok now i went outside just to see what the car would do and i hit the starter and it fired up and ran i tan like crap but it did start .anyways i cut it off went to restart it and now all i get is a huge backfire sounds just like a gun going off. ive checked the fire it seems to be good but how do i know if its enough? andways now all it does is that really lound bang.if i hold the gas half throttle and try and start i dont get the pop but it hits and acts like it wants to start if i give it no gas at all at the peddle i just get a extremyly lound pop
Jul 4, 2005 05:00 PM
