Belt Drive on a LT1
Old Sep 29, 2002 | 06:45 PM
Daddyo's Avatar
Belt Drive on a LT1
would like to know if a jesel or comp cams belt drive will fit and work on a LT1 motor. If it's just minor machine work or a PITA. going to run a carb motor so no need for the opti. Not sure if this is advanced or not but if it is you'll just move me anyway. Thank you.
Old Sep 29, 2002 | 10:06 PM
sleeperz28's Avatar
just get an electric water pump and a sbc would work. Im assuming instead of a timing chian correct?
Old Sep 29, 2002 | 10:13 PM
OneFlyn95z28's Avatar
the timing cover is a different shape. if you could over come that and it cleared a LT water pump you would have it made
Old Sep 30, 2002 | 01:31 AM
zturbo's Avatar
Lt1 Motorsports car if they still have had one on it. Not sure what all was done but they ran one back in 96 or so
Steven
Old Sep 30, 2002 | 09:23 AM
Daddyo's Avatar
I have an electric water pump now. SLEEPERZ28 what do you mean buy getting a sbc? I want to put this on my LT1?
ONEFLYN95Z28 that's what I thought would be the biggest problem,was the backing plate. The water pump should be no problem.
ZTURBO I'll check out there site if they have one and see what's up.
Thank you all.
P.S.
Anybody else have an idea if this will work?
Old Sep 30, 2002 | 11:30 PM
zturbo's Avatar
LT1 Motorsports site..
I almost had a motor built by Brian but I just prefered another source. I never really went into detail looking what it took to work but i dont think it would be that hard to make work. There is a few pics in the ss396 area of his motor with the belt drive on it looks like he added a little piece above the belt drive to cover over the rest.
Steven
Old Oct 2, 2002 | 08:11 AM
Cmarsh93z's Avatar
Im pretty sure the bottom bolts are the same for the SBC cover, you just have to fabricate a plate to cover the missing space up top. The SBC cover is "shorter", and you need to add alittle length up top, with a small plate. Drill it out, add some bolts...and you are home free!
Chris
Old Oct 2, 2002 | 08:40 AM
Daddyo's Avatar
Zturbo:I checked out the site and yes they do have some pics with the belt drive on it. I sent Brian an e-mail.
Cmarsh93z:Thanks for the info.
Now to see what I can do for a lower alt. mount with the motor plate I have.
Old Oct 3, 2002 | 11:45 AM
Daddyo's Avatar
Thanks aggiez28. Going to shoot him an e-mail.
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Snoman73
Nov 17, 2014 07:22 PM
1LEThumper
Jul 14, 2003 12:45 PM
