Insanest cam on VORTEC heads
What is the most duration and lift could run on stock vortec heads moded to take more lift Before the heads would them self would cause restriction?
I was thinking of runing 230 to 238 maybe even up to 240 some thing on the exhaust side.
How big can you go?
I have a 700R4 and 3.23 gears but I will change them along with the torque converter.
How big can you go?
Well, as far as duration goes, it's really a matter of how much motor you have under the heads.
A smaller motor will reach the peak flow of the heads at a higher speed, and therefore would probably require a cam with more duration. If you look at extremes, something like a 427 SBC would reach peak power much earlier in its rev range and would require a comparitively smaller cam than, say, a hot 283 with the exact same heads (I'm neglecting the effect of the bore diameter on valve sizing and port flow for the purposes of this discussion).
So, bottom line - there's no absolute limit on duration. Putting a big-displacement motor under stock Vortecs and then going wild with cam duration might be a little disappointing, though.
Now, lift - that's a different story. There's the issue of mechanical limits due to retainer/seal interference, the possibility of contact between the pushrods and head with 1.6:1 rockers and high-lift cams (an issue with some iron LT1 heads - I don't know if Vortecs suffer from the same problem), and then the limit of the valve springs - both from a coil-bind standpoint and from a lack of seat pressure. Your best choice here is simply to throw away the stock springs and have a machine shop rework the spring seats and guides. You should be able to accommodate .550+" of lift with these simple mods and a good set of springs.
i am running the performer rpm cam with 1.6 rockers i just got these springs so that i didn't have to machine the heads
http://store.summitracing.com/partdetail.asp?part=26217
justin
justin
You mentioned p rod and head interfearence on vortecs, Yes it does happen.
The moded heads I was looking at were cleared up to .580'' but were not ground out to prevent push rod scuffing.
The bottem end was going to be a stroked 350 (to 383 or 396).
Chris Anderson
Jan 27, 2015 08:30 AM
