ceramic coating question
Old Oct 27, 2002 | 01:03 PM
keven's Avatar
Will a head gasket seal if i have the whole side is ceramic coated, not just the chambers?
Old Oct 27, 2002 | 01:29 PM
Mindgame's Avatar
Good question.... I don't believe coatings change the surface finish enough to cause a sealing problem. That'd be a question to ask one of the coating companies though.... if you don't get a definite answer here, I'm sure Swain could tell ya.
-Mindgame
Old Oct 28, 2002 | 09:17 AM
carl97ss's Avatar
Thumbs up
no problem.
Old Oct 28, 2002 | 08:29 PM
Jesse_Boyer's Avatar
ok, i'm confused. you're having the gasket coated, or he head surface? this is all new to me so i'm learnin'
Old Oct 28, 2002 | 09:22 PM
nosfed's Avatar
I just finished coating a set of pistons, and my guess is that its less than a thousandth thick. Considering that most aluminum heads that come into my shop that are aluminum are warped at least three thousandths...... not a sealing problem. After the finish is polished with 0000 wool it's probably a quarter of a thousandth.
The film lubricants go on a piston and wear to a couple millionths thick.
99TransAmWS6
Feb 12, 2015 07:23 PM
Jcb890
Sep 9, 2002 11:30 AM
kandied91z
Jul 20, 2002 03:56 AM
