Using LT1-designed cam in L98?
Old Sep 27, 2002 | 07:29 PM
Whistler's Avatar
I am putting together an engine for my neighbor, it's a 91 Vette with an L98. I want to run the CC305 or CC306 LT1 cam in it, as the LT1 intake is similar to the MiniRam intake we're using.
Engine has AFR 195s, longtubes, 58MM TB...etc.
Anybody had any problems?
Old Sep 27, 2002 | 07:31 PM
89ProchargedROC's Avatar
The dowel pin on the cam might have to be grinded down or changed....measure to be sure
Old Sep 27, 2002 | 07:53 PM
Eric Bryant's Avatar
If your neighbor hasn't bought the cam yet, you can get a CC305 or 306 grind on a normal roller-lifter SBC core. If you've already got an LT1-core cam sitting around, you can pound in the dowel pin to the correct length.
Old Sep 27, 2002 | 09:02 PM
Whistler's Avatar
Other than the dowel pin, is there any difference in an LT1 cam and a 86- SBC?
Old Sep 27, 2002 | 11:53 PM
well you said its a 91 vette....not you say it has an 86 motor
did it come factory with a roller cam or not?
Old Sep 28, 2002 | 02:43 AM
BlackHawk T/A's Avatar
It would have come factory with the L98, and did until the LT1 arrived for 92'.
Old Sep 28, 2002 | 10:13 AM
LT1 cams have a larger pilot hole in the nose of the cam, to accomodate the Opti.
rideordie
Nov 5, 2019 04:52 PM
Queens94z28
Nov 20, 2014 06:03 PM
Chris Ja
Aug 1, 2002 07:30 PM
