Cam Question
Old Oct 17, 2002 | 11:00 PM
Distortion28's Avatar
Cam Question
the larger cams with around .525 inch lift are said to be best used at approx 3500-6000 rpm, compared to one with lets say .484 which would be like 1000-4000 rpm, my question is would that larger cam have the same effectiveness at lower RPM that the smaller cam does, is it just that it does better on upper RPM
Old Oct 18, 2002 | 02:01 AM
SStrokerAce's Avatar
depends upon alot of things. First take a look at the "cam gurus" thread down the page. That will help you some, then ask a more specific question.
Bret
Old Oct 18, 2002 | 04:09 PM
bowtiepwr's Avatar
>I used to have the Crane Cams PowerMax 2050 ( http://www.cranecams.com/master/apps...#2.%20CompuCam ) with 1.6 roller rockers on my stock bottom end LT1 (AFR heads , headers , 3"exhaust , etc.) It seemed like the motor dogged out a little below 3000 rpm's but was like an animal above 3000 rpm's . Where the stock cam had it's power through out the rpm range .
I hope this makes sense .
Later ...
stay safe
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
