Gen I 383
Old Oct 9, 2002 | 09:01 PM
Faccnator's Avatar
Gen I 383
So guys, I am going to swap a 383 from a 71 Impala into my 95 3.4L. Its carbed, what problems will I have, what can I do.
Thanks,
Faccnator
Old Oct 10, 2002 | 04:39 PM
Faccnator's Avatar
It is a Gen I Block. I have gotten the feleing that it will be harder or differnet from swappint a Gen II (LT1) block in. So, what are the differences, what can I do about them. I am really more curious about the block problems than the cowl clearance issues because of tha carb, although if you know how I can keep my wipers when I mod the cowl, that would be great.
I know you guys know this stuff! (Injuneer) Help
Old Oct 10, 2002 | 04:41 PM
89ProchargedROC's Avatar
um....it will drop right in pretty much
Why would there be any block problems when you plan to use the Gen I block?
the only thing i can think of is cowl clearance and you will have to run a crab-crap low profile distributor cap to clear
Old Oct 10, 2002 | 05:00 PM
Faccnator's Avatar
I don't know, I figured that it would fit right in using SBC Motor Mounts. There was a previous post where Injuneer was curious about the block a kid was using for a 396 swap, so I figured it must matter that I was putting a Gen I block where a Gen II block normally goes.
Also, its going to be carbed and even though I have chosen the lowest profile stuff I can find, I know I am going to have to trim the cowl. The wipers are in the cowl and I don't want to lose them, am I going to have to cut them out like I have seen on the drag only cars?
Anyway, just some thoughts.
Old Oct 11, 2002 | 07:14 PM
SStrokerAce's Avatar
Why carb it?
Old Oct 12, 2002 | 04:01 PM
Faccnator's Avatar
Well, money I guess. I can't afford a $2000 fuel injection setup, so I went with a Holley Double Pumper at least for now. Also, I can tune a carb, I don't know about that FI stuff.
Old Oct 12, 2002 | 05:20 PM
I understand that. Sometimes the pain of EFI makes all it's advantages and cost go down hill.
jdelaprida
Jul 4, 2015 03:02 AM
Drtryder
Apr 22, 2015 04:17 PM
cheapchevy
Apr 8, 2015 08:48 PM
