Guys with fast 6 spds, what do I need to keep from breaking them
Old Oct 27, 2002 | 02:07 PM
GreenbeanZ28's Avatar
What do I need to do to keep from snapping input or output shafts? I am thinking of having them cryo-treated. Has anyone else out there had this done? By the way, I am building a 383 motor with plans to spray it, I need to know what I have to do to keep from putting in an automatic. Thanks a bunch
Russ Ethridge
Bolt on 96 Z28
12.34@109.7
sprayed...11.27@119
Old Oct 27, 2002 | 05:49 PM
jimlab's Avatar
Talk to D&D Performance. www.ddperformance.com
Old Oct 28, 2002 | 12:21 PM
CobraKilla's Avatar
Relocate the torque arm.
Old Oct 28, 2002 | 12:25 PM
Mikael's Avatar
Are you currently breaking your shafts??
Rich has a very fast M6 and isn't breaking anything.
Old Oct 28, 2002 | 01:51 PM
The torque arm is relocated. No, I havent broken anything yet, except for that damn 3-4 shift fork...keeps getting stuck in 4th gear. I just know that sooner or later I'm going to have trouble with breaking output shafts. I've heard of a few done before, but I dont know the exact point power-wise that I am going to start breaking stuff.
Old Oct 28, 2002 | 02:02 PM
Kraest's Avatar
Retired
I agree. Get in touch with D&D Performance:
And stop powershifting
Mike
Old Oct 28, 2002 | 02:16 PM
Kraest's Avatar
Retired
BTW, this should have been posted in LT1 Tech..
Mike
Old Oct 28, 2002 | 02:59 PM
rskrause's Avatar
Moderator
~775rwhp (haven't dynoed it since going from 150 to 200hp nitrous) with still intact T56. I am getting it rebuilt with the Viper output (and ?input) shafts this winter to see if it's up to 900-950rwhp! If it breaks: G-force 5-speed.
Rich Krause
Old Oct 29, 2002 | 01:07 AM
CAJUN-Z's Avatar
From: from the land of Justin Wilson and Huey Long!
Here's the pricelist for D&D for the G.M. T-56. You could upgrade to the viper T-56 for $3700...also from D&D...
Old Nov 1, 2002 | 12:35 PM
atljar's Avatar
Improper TA pinion angle is the biggest cause of broken input and output shafts.
One of my friends just ripped apart his input shaft. I think he set up the Sphoon TA with too much pinion.
Anyways, D&D is designing a kit to convert the f-body 27/28 spline input shafts to the viper/03 cobra 31/32 spline. Suppossed to come out sometime next year.
Either way, the t-56 we just tore apart is getting sent off the get all the internals cryo treated. I'll let you guys know how it turns out.
Jared
Old Nov 1, 2002 | 01:26 PM
Ponyhntr's Avatar
GreenbeanZ28-
Mine keeps getting stuck in 4th gear also. When it first happened, I thought it was the shift fork, so I replaced it with the steel unit. Then out of the blue, about 3,000 later, while I was just driving normally, it got stuck in 4th again. I wasn't even getting on it!! I pulled the tranny out of the car about a month ago, but I haven't pulled it apart yet. I'm thinking I might have a bent shift rail or something. Anyone else have an idea as to what is wrong?? Thanks for everybody's help!!
maybe2fast
Mar 16, 2015 09:45 AM
grabbem88
Feb 13, 2015 03:09 PM
maybe2fast
Feb 5, 2015 05:14 AM
Jason Short
Jan 19, 2015 06:34 PM
Red97LT1
Aug 7, 2002 05:45 PM
