BBC in 4th gen Camaro
Old Oct 30, 2002 | 03:07 PM
Revolutionary's Avatar
Contemplating a BBC in 4th gen Camaro for strip use. Has anybody got info on pitfalls? Carb to cowl clearance? Distributor clearance or run a front drive? Header clearance? Anyone put a kickout pan on there with stock crossmember, even on a small block? Anything else helpful?
Old Oct 30, 2002 | 08:26 PM
DTK's Avatar
DTK
I have contemplated doing this as I am a BBC diehard. Silly Rabbit Small Blocks are for kids.
I have not begun this, but I was going to run dual PCM's and dual throttle bodies. Make my own intake by shaving the tops off two LT1 intakes and making a sheet metal intake. I have allot of the concepts mapped out. You would have to blister the hood because the BBC sit higher. I was going to put a Turbo 400 or a glide behind it. Will fit no problem. I just need to find a 4th gen body. Good luck with this. maybe I will beat you to it.
Old Oct 30, 2002 | 08:33 PM
Mikael's Avatar
It has been done, so its possible. I don't have any facts other than that for ya though. Best of luck.
Mike
Dec 31, 2014 02:21 PM
ChrisFrez
Dec 21, 2014 09:47 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
