max lift recommended ???
Old Oct 29, 2002 | 04:36 AM
bowtiepwr's Avatar
>When a cylinder head company (i.e. AFR ) states : 1.450" OD Hydraulic Dual Valve Spring, 120 lbs. on seat, .550" maximum lift, AFR #8020 .
Is the company (AFR) talking about cam lift without the roller rockers (i.e. 1.5 rocker ratio) or is this total lift whether using 1.5 or 1.6 roller rockers ?
Old Oct 29, 2002 | 05:24 AM
rskrause's Avatar
Moderator
Re: max lift recommended ???
Lift at the valve ("total" lift).
Rich Krause
Old Oct 29, 2002 | 01:34 PM
bowtiepwr's Avatar
>That includes rocker arms too ... cool
Old Oct 30, 2002 | 03:23 AM
oil pan 4's Avatar
It says .550''.
Theres 2 ways to get .550''
A .550'' cam with standard 1.5 rockers.
A .520'' cam with 1.6 rockers will give you .550'' +- a few .001's.
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Beave2780
Sep 23, 2015 12:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
