PDA
View Full Version : V6 Tech
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. 3.8 V6 Labored Start when warm
  2. 3.8 V6 Trans Mount to LT1 style
  3. Belt squealing, but only when under a load.
  4. 99 3.8 no start
  5. Air conditioning
  6. 94 v6 - "misfire" falling on its face. desperate for help interpreting logs
  7. Poor Man's Camshaft Lobe Hardening Treatment
  8. Misfire to knock
  9. 1st time owning a camaro
  10. Horrible gas mileage
  11. 1995 3.4l camaro won't start
  12. 3.4l to 3.8l swap in 94' camaro
  13. Oil in Coolant Plus lean and misfire code
  14. Engine randomly stalls out while driving need some help here
  15. 94 retiming
  16. Replace head gasket or replace engine...
  17. joe junk
  18. New part
  19. engine oil dipstick
  20. Intake leak
  21. !995 3.4L cylinder #2 flooding
  22. LT1 Fuel pump in 3800 Car?
  23. 96 camaro rs exhaust flange bolt size
  24. Energy suspension trans. mount??
  25. 1995 Camaro 3.4......power adders????
  26. 94 camaro vats problem
  27. 3.8 pacesetter mpg change
  28. 2002 camaro 3.8 idle help
  29. 2000 tubular manifold swap
  30. P0102 MAF issue.
  31. please help
  32. 2001 Camaro
  33. 95 3.4 low oil pressure worries??
  34. Cam upgrade 3.8 ???
  35. 1998 Camaro help! Rear end? Transmission? Seattle,Wa
  36. A/C Compressor Bypass Pulley Belt?
  37. p0300 from Hell! Please help!
  38. Coolant Problems?
  39. 2000 camaro v6. So confused
  40. 94 camaro not cranking
  41. 96 firebird 3.8 V6 seal question
  42. 98 3800 Oil Pressure Sensor Problem
  43. Stock 3800 V6 cam?
  44. Comprehensive tty internal bolt list for 98 3800?
  45. loud ticking on a 97 3800
  46. loud ticking sound 96 rs 3.8
  47. Converting to a 7mgte
  48. Scan9495-V6 OBD1 utility for 3.4L F-cars
  49. Shifting from 1 - 2
  50. Time to pull the motor!
  51. Going Crazy
  52. oil pickup tube?
  53. V-6 Rebuild
  54. Rear wheel positive stock???
  55. Harmonic Balancer Help
  56. 2000 camaro v-6 Auto
  57. vats locked down my 95 3.4 camaro
  58. 96 rs
  59. Engine Squeal
  60. 1988 camaro wont crank with key
  61. 1995 3.4 V6 starts then dies, please advise
  62. Thermostat and P0128
  63. 1995 camaro 3.4 V6 Will not start
  64. 3.8 belt tensioner assembly
  65. Jumping cylinder misfires
  66. if you have a picture of a M/T 3.8 flywheel for a series 1 & 2 please post it.
  67. 1997 3.8 automatic and manual harmonic balancers the same??????
  68. ia relevant organizationsIntegrity ended celine
  69. 92 firebird
  70. oil pressure sending unit
  71. 3.4L Fuel injector clip
  72. Battery Ground Removal. Vats activated
  73. car starts....sometimes
  74. Windshield weatherstripping/water on floorboards
  75. rod/crank clatter? something terrribly wrong with this 97 3.8
  76. Pull motor through bottom or top?
  77. 98 camaro 3.8 v6 overheating problem
  78. V6 3.8L Rough Idle Need Help!
  79. Power Steering delete
  80. Is a 97 3.8 very hard to rebuild?
  81. 3.4l swap to 350/LT1 or turbo?
  82. Alternator not charging after changing serpentine belt
  83. 97 camaro
  84. 2001 v6 camaro
  85. starting problems
  86. Short Throw shifter 3.4L
  87. Need some advice
  88. car cuts out
  89. 1994 V6 Wont start and was acting up??
  90. Frustrating problem, need help!
  91. Plenum Opening Size
  92. 99 3.8 camaro question
  93. 99 firebird anti freeze leak
  94. need some wiring help, fender plugs
  95. Rain Water getting in oil while parked!!
  96. Fuel pump overheats???
  97. 1994 camaro v6 3.4L
  98. v6 swap
  99. oil psi dropped to 0
  100. car not starting
  101. Opinions on leak fixes for my 95 3.4?
  102. 02 Camaro v6 won't start
  103. power LS door switch
  104. z28 a v6??
  105. Lost power on expressway and now knocking
  106. no hazard and tail lights stay on
  107. 97 Camaro Coupe MAF Issues
  108. 94 3.4L camshaft removal help
  109. Head Bolts 94 Camaro 3.4
  110. 95 3.8 issues I need help
  111. want advice on a 383 stroker build!!
  112. Engine Harness?
  113. Heat issues messing with my computer
  114. 94 Camaro 3.4 cooling issue
  115. 3.8L lost coolant, overheated, now knocks on rev up.
  116. preformance module
  117. overheating please help if u can
  118. wiper question
  119. 97 RS Part list Help
  120. 1994 camaro 3.4l fuel pump shuts down
  121. Will a 1995 4l60e fit in my 1999 camaro
  122. What transmission do I have? 1999 camaro 3.8
  123. What should I replace next?
  124. 1993 z28 backfiring after warming up
  125. 99 firebird V-6 issues
  126. 1999 camaro 3.8 auto transmission problems
  127. Need help with M5 tranny!!!
  128. v6 to v8 swap LT1 into a 2002
  129. Bad Cylinder 3.8L
  130. random misfires, too rich bank 1 and too rich bank 2
  131. 99 Maro hard starting
  132. 99 Maro hard starting
  133. overheating after new thermostat and flush??? help if you can plz
  134. Misfiring and ABS INOP?
  135. electrical problems
  136. Speedometer recalibration?
  137. Brown sludge in my coolant
  138. Heater/AC Control Problem
  139. 95 v6 3.4 mileage problems
  140. 96 Camaro RS - Replace Oil Pan Gasket Questions
  141. electric help plz relay box under passenger air bag
  142. new clutch and release bearing
  143. Oil pressure dropped to zero on HWY, and now motor knocks
  144. different misfire?
  145. have 2 Broken AC/idler bracket bolts in block please help
  146. 95 3.4 camaro misfire mystery
  147. Car wont start, very wierd
  148. 95 3.4 Camaro Wont start (lots of details)
  149. interior lighting
  150. engine codes
  151. 1998 camaro v6 having prolems
  152. surging while comming to a stop
  153. Temp help/fan
  154. Misfiring...
  155. 2000 Camaro 3.8 V6 Oil Pan Removal
  156. What is this part called?
  157. oil leak
  158. Unidentified sound while shifting
  159. how to increase horsepower in my 98 V6.
  160. Spuddering Misfire? Where to Start
  161. 97 3.8 with weird sound coming from air cleaner area.
  162. 94 3.4 won't crank, and no power to the fuel pump. PLEASE HELP
  163. 3.8 oil pressure
  164. 97 3.8 leaking coolant need help!
  165. New motor= New tranny?
  166. brake lights stay on and no flasher
  167. eliminating 97 3.8 plastic fuel lines ????? How can it be done?
  168. HELP PLEASE!!! 2000 Camaro wont start up
  169. grommets
  170. 3.4L Drive-shaft Center Support Bearing.
  171. wiper blades
  172. oil fillertube grommet
  173. CAI on 1997 3.8
  174. Mass Air Flow Sensor Wiring
  175. rattleing/bad bearing noise... waterpump?
  176. Engine instantly dies upon cranking
  177. 4th gen engine issue
  178. 96 rs ride height
  179. Camaro cranking/starting problem help me
  180. How long is a 3.8 Camaro good for?
  181. 86 camaro v3?
  182. one side wet
  183. No injector fire on hot soaked engine
  184. 0-60 guess??
  185. 98 runs then wont start
  186. 91 3.1 dies after warming up
  187. Electrical problems
  188. cam ?
  189. 1996 camaro v6 to v8
  190. 3.8 supercharger
  191. 95 camaro new motor problems
  192. Starter starting with no key..
  193. 3.4 intake elbow to 3.8?
  194. *URGENT* 97 RS Engine/Transmission Shaking
  195. Timing Chain Cover
  196. Electrical question
  197. please help EGR problem.
  198. 96 rs fuel pump not coming on
  199. Help! ran out of coolant, car died
  200. crankshaft sensor? Where is it located?
  201. 96 won't start
  202. Is this thing worthwhile?
  203. Oil Gauge Fluctuation, Start of a Knock
  204. Another Issue with the 3.4
  205. Test drove a firebird today, now for a question
  206. IAC valve
  207. Programming
  208. 1997 oil leak
  209. low idle
  210. Check engine light
  211. 1995 camaro 3.4 mods?
  212. rpm's jumping when foot is not on pedal
  213. 2000 pontiac gtp vs 1997 v6 camaro
  214. 95 3.4 ticking noises
  215. oldsmobile 3800 work for 95 camaro?
  216. swapin 3.4 for 3.8 question
  217. 3800 turbo or supercharger?????
  218. plugs and wires install 1997 3.8
  219. K&N air intake for 96 3.8
  220. Part Replacement Questions for Non-Stock Engine
  221. swapping 3800 v6 with sb 305
  222. Alternator Replacement
  223. Sensors for O2 and air bags
  224. 2000 camaro 3.8 v6 help out
  225. Headers and Y-Pipe on a 2002 Camaro V6
  226. 3.8L Mods
  227. trans issue 3.8l
  228. 94 3.4 T5. Out for the season/ Battery terminal junction
  229. 1998 v6 car wont start
  230. P0171 & P0174 codes at the same time!
  231. 96 RS issues
  232. 3.8 work in a 3.4 tranny?
  233. 96 camaro question on engines
  234. 95 camaro power issue?
  235. code reader
  236. Can Some one Please send Me A link for the power dyne supercharger for the 3.8l
  237. 5 speed Camaro v6 making noises
  238. timing cover replacement
  239. Starter question..
  240. Another 95 camaro that wont start!
  241. 3.1 Wont Run Without Start Fluid
  242. Fuel in oil?
  243. 3400 overheating
  244. 95-97 CAI on 2000?
  245. Damn starter removal...
  246. 3.8 to 3.4 engine swap, newbie.
  247. Ohio newbie, engine swap
  248. P0306 code
  249. 95 3.4 missing lik dropping a cylinder
  250. car won't start until tomorrow
