1995 camaro 3.4 V6 Will not start
Ok. The fuel pump is good. I'm getting spark. The Injectors are getting power but will not pulse. If you spray gas in the intake with a bottle it starts till you stop spraying gas. Its not vats the security light does not stay on or flash on and off. Just comes on for a sec then off and that's it. Any Ideas or further tests I can do? I know the pump is good the fuel pressure was tested.
Re: 1995 camaro 3.4 V6 Will not start
Check the fuse. Could be blown. Thats the only thing i can think of next to disconnect the battery for a few minutes. There should be 4 wires, power comes the fuse block, and then grounds, and the ECM sends a signal then ground. So it needs to be one or the other. If its not a fuse or constant power problem, it has to be a ECM issue.
Fuel pump is good. Holds steady 41 psi. I have had people tell me it could be a ground wire. Still looking. I have tried a different ECM still no luck. But I could try another. I can not get any one to look at this car. Seems ware I live all the mechanics do not like to work.
Jul 4, 2005 05:00 PM
Chrisdude
Jul 24, 2002 02:25 PM
