91 3.1 dies after warming up
Helping my uncle on this car. It will crank over fine, starts hard but after a little massaging of throttle will finally start. It runs fine until the temp get up to where the fans kick in , about 10-20 minutes. It then starts running very rough, and eventually dies and will not start again. It has new plugs, rotor, cap, map sensor. Icm tests good. It thru a 35 code for the iac. He has it on order. Any suggestions. I told him possibley a 02 sensor since it runs good until its warmed up, isnt that where the 02s kick in and send signals to the computor. Its a 91 Camaro with the 3.1 litre v6. thanks for any suggestions.
Location: too close to the north pole ( Massachusetts )
Re: 91 3.1 dies after warming up
Check the electronic egr valve.
Open the hood look by your left hand near the coil and exhaust manifold. I put block-off plates on mine and just had it programed out of the memcal.
