Check engine light
Old May 5, 2011 | 03:35 PM
red97rs's Avatar
Check engine light
i have a 97 v6 auto with 112,xxx miles. My check engine light keeps coming on... and has been for the past 10000 miles... i went to autozone since i dont have a scanner... and it was code p0420
definition- catalyst efficiency low-bank
explanation- o2 sensors monitor the cat ability to store oxygen
probable cause
1. cat defective
2. engine misfire or running condition.
3. large vacuum leak
4. engine oil leakage into exhaust-valve guide seals, piston rings.
i have checked the plugs recently and they look good, and 2 of the 3 coils has been replaced within the last 20,000 miles. and, my fan and where it blows seems to be working fine still, so i dont think it is a vacuum leak or misfire unless its the wires...
what do you think i need to do?
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
