Engine randomly stalls out while driving need some help here
Old Mar 16, 2015 | 02:50 AM
Darth_tsunami's Avatar
I have a 97 3.8 camaro and recently it's been stalling out on me while driving ive checked the terminal cables and even replaced the battery and alternator as well as the spark plug wires and spark plugs along with all the fuses and relays and also replaced the air filter and I've also cleaned the maf sensor as well. I changed the fuel filter not to long ago Too. Here's the kicker though, I recently got a clutch/flywheel replacement done at this shop and they lost my keys which was okay cause they got my some new keys with the chip and all. My and tonight it stalled out on me twice and I have one chipped key and one with out that can still start the car, so I tried turning her over but wouldn't go, I used the other key and it started right up and vice versa with the second stall, what's going on with my car guys????
Old Mar 16, 2015 | 11:01 AM
Re: Engine randomly stalls out while driving need some help here
At any point have you scanned it for codes?
Old Mar 16, 2015 | 02:31 PM
Yeah it isn't throwing anything up which is what I find weird it had the SES on for a bit but that went away after I replaced the alternator
Old Mar 24, 2015 | 02:32 PM
ZeeS7o7's Avatar
weird! Have you told the shop that did work on your car that this has been going on?
Old Mar 24, 2015 | 02:36 PM
ZeeS7o7's Avatar
plugged cat??
Old Sep 10, 2015 | 11:24 PM
Aaront810's Avatar
Never mind I figured it out. Did some wiggling and jiggling and got it to work
Old Sep 18, 2015 | 01:57 AM
PublicEnemy1's Avatar
Check for a cracked ignition coil. I had similar symptoms and that was the problem. Mine would go weeks without stalling and didn't always cause a engine light.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
nophix
Nov 30, 2014 10:26 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
