- Dash lights freaking out
- Z28 camero
- 1995 3.8L V6 pcm tuning?
- Knock count going crazy, retarding timing, not sure what else to do
- Convert .eedata to .csv
- 1997 z28 lt1 no pcm communication, no start, need help
- 1993 lt1 scan/log
- Better wide band sensor?
- Trouble with my IAC
- Scan 9495 Results
- '93 Z28 w/383 LT1 - ECM Issued - Replace w/ FAST XFI System?
- No DTCs after scanning with scan9495
- ‘97 Z O2S12 and O2S22 not reading
- Im an idiot, Bricked PCM
- Scan9495 won't sync
- OBD-I vs OBD-II Knock Module Compatibility
- Charting Engine Variables Using Scan9495
- Retrieved the the following error codes from my 93 z28 .
- Reading ABS codes
- I'm Having Problems Datalogging With Scan 94/95
- GD Scan giving me an error when I try to connect
- Anyone Have A Good Tune For A 396 LT1 They Can Share?
- Does the scan9495 help with bleeding abs brakes
- Computer
- 96 LT1 with 95 PCM. Issues?
- 97 Camaro SS Alternator Overcharging
- Where should this plug go?
- FAST XFI ecu on our cars?
- DTC codes 48, 42, 36
- NEED HELP!!! car stuttering at low throttle any rpm. i have a log.
- Data Cat anyone have it with fast wideband?
- Car not ready monitors
- 2001 Camaro z28 not ready for emissions koi i
- Scan9495 data log help
- Tuning question
- LT1 surging.
- 2000 Camaro cd err message
- Can OBD-II emissions be conserved through a 496 bbc swap?
- '95 Z28 LT1 Opti 36 Check Light SES Stumble Poorer Fuel Eco Repairs Knock Sensor
- LT1 Battery Relocation Issues
- Car seems to go lean at WOT
- PCM/Tuning - 1st start of the Day
- LT1 randomly decides to go lean
- Logging AEM UEGO wideband on a OBD2 LT1
- "Bricked" PCM repair
- LT1 will not enter field service mode
- Set WOT shifts on a 4L60E?
- Alarm Issue on a 1997 Camaro
- LT1 PCM Scanning Guide
- Scan9495 Observations?
- Wideband question
- Runs good in open loop but pumping idle and with same throttle in closed loop
- DLC not working
- How to get the most out of a stock lt1?
- Tach goes crazy
- V6 PCM for monitoring/gauges only
- Does LT1 Tuning Still Exist?
- LT1 Tuning / Dyno Tuning Help!!!
- What is this Ford O2 For?
- Using GM Tech 2 on a Camaro 1997
- 97 LT1 Pcm in 95?
- Fuel trims
- EEHack help
- Need stock LT1 WS6 Ram Air MAF tables for OBD 1
- Issue with vats
- Pretty sure I cooked the ECM - TunerCats
- Trouble finding injector voltage offsets for Bosch EV6 (0-280-155-831)
- Egr code state inspection advice
- P0300
- Data Log
- LT1/LT4 ESC module needed
- IAC/TPS questions
- A free manual?
- Cooling Fans Constantly On
- Need FAST XFI .gct file
- Help
- Computer tuning to add back cats
- We hack problems
- Could someone please review my scan9495 log? ive need help please.
- Engine misses when warmed up.
- Obd1 and obd2 tuning
- Instrument Cluster swap
- 1997 Trans Am Running rough and rich HELP
- Swapping a 96 Caprice LT1
- 1994 Z28 shift RPM
- Mass Air Flow sensor
- 97 LT4 tune question.
- Scan94/95 datalog request
- Does the GForce Performance Chip Improve MPG and HP?
- LS1 MAF sensor
- VATS bypass. 3 or 3 thousand Ohms?
- Chasing gremlins - Scan9495
- 94 Trans Am Rough Idle
- 95 z28 with 383 big cam stalling
- Fried my PCM - Repair options
- ABS code 34
- Upgrading laptop
- Sensor ground voltage
- Datalog Analysis Request
- Could you read my Data Log 5/30/16
- TunerCat Speedo Help Needed
- I can't find the DLOG or .csv files
- 95 z28 backfiring
- Comp tuning help??
- LTFT High at idle on Bank 2 only - Logs included - PLEASE help!
- New Data Logs...Please Help!
- 1995 OBD1 tuning help!
- Throttle sticking
- Want to run cooler thermostat need PCM values
- Idle stumbles/fuel trims jacked
- Can't install on Windows 10
- Need Help car wont start possible computer or sensor problems
- TTS Daamaster And Windows 10
- Bad running Z-28
- No communication with vehicle
- Scan93
- how to tune lt1
- Superchips Flashpaq 4
- Free Scan for 94 lt1
- Automakers lost lobby to prevent PCM modifications...
- Battery Maintainers
- need some help guys
- Tuning Question
- openloop table
- Intake air temp
- backfires and missing scan9495 log
- tuning software for 95 camaro?
- Code 43
- P0113&p0305
- Differences between 94 and 95 programming
- Missing and sputtering with data log
- TunerproRT
- Tuning help, have log
- Ls1 in need of tune
- 94Z bricked PCM help
- Tunerpro after pcm4less and MSD timing
- P1416 code.. 2000 Z28/SS
- Induction popping red hot headers
- Tunercat help!!!
- Brain dead - appreciate help
- VSS Diagnostic question
- Anyone want to interpret II
- Starting issues... wont even turn over
- Tunerpro question
- Cable Question
- Battery relocation Voltage Issue
- Strange P0300 code
- Dtc 25
- TunerPro data acquisition..
- PCM not communicating with OBDII 1995 LT1
- P0480 & P0481 codes
- Tune ???
- Jet Chip
- 2 quick questions
- Scanning a 95
- Dreaded P0300 code
- need a little help
- Idle surging
- What do I need to remove speed limiter?
- Please help me
- 1993 z28 lt1
- Sudden PCM death
- 93 LT1 added to Scan9495 app (Version 2)
- Need help with Wiring for MAF
- Warning: OBD1 or OBD2 cables may get trashed by FTDI update
- emissions delete
- programming questions. new to trynna tune a computer controled car
- windows 8.1 and scan9495
- Warning: Chinese OBD2/ELM327 Bluetooth adapters missing key parts
- Getting a P0300 code but no problems
- Datalog help needed
- ALDL cable problems
- LT1 4L60E to T56 tuning, how to save custom tune?
- Tuning help
- Tech 2 clones come way down in price
- Couple ? - data log and tuning for a 93 auto
- 1995 z28 engine code
- Oxidized connector fun...
- Anybody know if MadZ28 is still around?
- tunerpro glitchy
- Please check out my datalog
- can someone check my datalog?
- Yank SS3600 Stall converter tune
- Datalog from 93 with Low RPM Hesitation when Warm
- New to forum, looking for tuning answers.
- A few weird things Ive noticed while datalogging. But are they important?
- Tips I found out over the past week-erratic idle/O2's/Running lean.
- Mysterious missfire.
- Is anyone available to look at my tune (pulled from Tunercats) 383 LT1 95 T/A
- Help with datalogs
- Manual fan switch help
- Missing/Hesitation after lt header install
- Data log questions?
- Please help!!!!!!
- 94 Z again..new opti ??
- 1981 Z-28 Computer-Possible Problems
- Rules for selecting from 4s shop, chain fast repair or local garage
- Help with SSI-4; since Innovate won't help
- MAF signal spiking low
- Open loop Idle possible? 96 OBD2
- losing 1st and 4th after tune
- Datalog analysis please
- ABS Inop. Light
- Replacing ASR/ABS rear-end with no reluctors
- Tuning Question
- Best way to run a datalog scan?
- 24x conversion on 94 with OBD1 connector
- Help, 94 Z28 Code 33
- can someone please look at my datalog
- LT1 z28 ECU Tuning option?
- Real time tunning
- 99 z28 bcm issues
- Torque pro app
- 2800 stall on a 3600 tune?
- Baro Reset
- 96 impala, OBDI, tach solution?
- Just confused..
- can someone look at my datalog?
- OBD-II PCM's interchangable for 96-97 LT1?
- 94Z with 93TA engine - possible PCM issue? - Newbie alert!
- Changing pcm vin obd2
- 97 LT1 fried ecm?
- 4l60e not getting command to shift
- 1986 camaro TPI 305 code 34
- Suggestion on ecm tune
- Error Code 77 issue
- Need '94 LT1 PCM ASAP
- HP tuners MPVI cable?? LT1?
- Strange Timing Reading on Scan Tool
- replacing bad PCM 1994 OBII AT
- OBD2 scanner with air bag for 96 Z28
- Knock Sensor
- Problem logging wideband in Datamaster
- OBD2 Scanner
- LT4 Knock Module
- at least read then decide if needed to be here or not if not ill move post please!!!
- New MegaSquirt MS3-Pro PCM on 15+ psi LT1 Thread
- IAC Range To Low - Low Idle When Cold But High Idle When Hot
- Service Engine Light
- Want new (better) tune for my LT1 supercharged car
- TunerCats: Injector Flow Rate Vs DISPLAY Injector Flow Rate?
- Help with Data file.
- 94 LT1 OD1 Driver Issues
- Help needed with timing issues 1995 LT1
- OBD 2 scan tool $84.99
- Please view datalog
- Modified LS1 won't Idle
- anyone have a 1996 Z28 A4 - Stock tune file
- Freescan
- Need an ABS code scanner. Monitor 4000e?
