OBD-II PCM's interchangable for 96-97 LT1?
Old Nov 18, 2013 | 04:47 PM
6SpdLT1Z's Avatar
I was wondering if I could run a '96 PCM in my '97 LT1 without any issues. Also, if the PCM was tuned for a similar setup (M6, 3.42, LT headers, !emissions) that matches mine would there be any concerns there?
I've only messed with tuning with EFI live, I know if you do a PCM swap on my truck you would have to perform crank re-learn and security re-learn.
Old Nov 25, 2013 | 01:34 PM
6SpdLT1Z's Avatar
Re: OBD-II PCM's interchangable for 96-97 LT1?
40+ views and no replies?
Old Nov 25, 2013 | 04:53 PM
parkers Z28's Avatar
I would say no ... but I'm just guessing
Old Nov 25, 2013 | 06:00 PM
Both the 96 and 97 are OBD-2. The wiring diagrams are essentially identical. But I looked around and couldn't find any confirmation that the PCM's are or are not interchangeable.
Old Nov 25, 2013 | 08:18 PM
ACE1252's Avatar
I'm not sure if they are interchangeable either, but they do have different part numbers in the GM parts manual(16214399 = '96 and 16242921 = '97). I went to look at my spare PCM in the garage and it matches the '96 part number in the parts manual. If I recall(it's been several years), I think I sent PCMforless a '97 model PCM and they exchanged it for a '96 for me when I purchased programming from them.
The 94 and 95's are the same parts numbers and the 93 is different as well.
I would bet that they are not interchangeable.
Old Dec 26, 2013 | 10:47 PM
2xLS1's Avatar
You can interchange them. I have.
Ringmaster72
Dec 12, 2017 10:12 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
cmdeshon
Jan 4, 2015 11:15 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
