96 LT1 with 95 PCM. Issues?
Old Jul 27, 2020 | 06:03 PM
chipndale4fun's Avatar
1996 LT1 motor with PCM from 1995 car. Any issues should I b aware of?
Old Jul 27, 2020 | 07:53 PM
Re: 96 LT1 with 95 PCM. Issues?
If the car has the 4L60E trans, it is not compatible with a 1995 PCM. Trans can be damaged.
4L60E year differences and interchanges.
The 95 PCM requires use of a 1993-1995 4,000 ohm knock sensor. Your 1996 engine has a 100,000 ohm knock sensor.
You will lose misfire detection, since the 1996 crank position sensor is not supported in OBD-1.
Life will be simpler because the after-cat O2 sensors can be deleted. Ditto with the EVAP system vacuum detection switch.
If you have an emission inspection that plugs into the DLC connector, it wont communicate because it’s OBD-1 and the scanning device is expecting OBD-2 data from a 1996 vehicle. May need rewiring of the DLC connection, as well.
http://shbox.com/1/DLC_wiring.jpg
1957camaro
Feb 17, 2010 06:54 PM
fstenuf
Aug 6, 2007 10:43 AM
gonzo69
West South Central
Dec 27, 2005 04:33 PM
SickWS6
Mar 29, 2005 12:53 AM
Black94mula
Oct 9, 2004 05:56 AM
