Steped caps or flat?
Old Apr 5, 2007 | 11:57 AM
VK's Avatar
VK
I noticed when you buy Pro-gram's billet 4 bolt-splayed caps you can choose between flat ones and the stepped ones. I know both blocks i have take the stepped ones, are the flat ones better? My machine shop said installing the new caps might cost extra if they have to work on them... are the Pro-gram's easy or hard? He said he's had to spend a few extra hours just to get the caps to work sometimes...
Old Apr 5, 2007 | 12:49 PM
1racerdude's Avatar
If your block has a step at each end of the main cap get the stepped ones.
Call ProGram and they will tell ya what ya need. They are knowledgeable and up to date. Just have to know what block ya have.
Old Apr 5, 2007 | 01:24 PM
VK's Avatar
VK
What about the machine work for the Pro-gram's caps? Are they ready to go so all you have to do is line bore and hone and your good? Or are they like the eagle ones where you have to play with them to get them to work after line bore and hone?
Old Apr 5, 2007 | 02:08 PM
rskrause's Avatar
Moderator
In order to register correctly in the block, all caps require machining.
Rich
Old Apr 5, 2007 | 02:15 PM
VK's Avatar
VK
Thanks rskrause, your pretty damn helpfull!
Old Apr 5, 2007 | 03:45 PM
WS Sick's Avatar
I know that if you are converting a two bolt to a 4 bolt you will need the stepped register.
Old Apr 5, 2007 | 07:53 PM
MachinistOne's Avatar
Not true.
We never use stepped caps, what is the point of upgrading to a stronger cap if you are not going to take it all the way and move the register point towards the pan rail, this increases rigidity of the whole setup.
Old Apr 5, 2007 | 08:21 PM
VK's Avatar
VK
So i should get the flat ones and tell the machine shop to spread the registers out on the block?
Old Apr 5, 2007 | 08:24 PM
Yes - make sure that they have done those conversions before.
Old Apr 5, 2007 | 08:33 PM
VK's Avatar
VK
k, thanks for the help!
Old Apr 5, 2007 | 09:14 PM
Alan Namsa's Avatar
Another vote for the flat caps. And, as was said before, best it is to find a shop with a good history of this process.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
heus
Sep 8, 2015 12:01 PM
