Max safe Compression Ratio for pump gas
Stock Lt1 10.4:1
Stock Lt4 10.8:1
Depending on the gasket thickness I can be anywhere between 11.1:1 to 12.2:1.
What is the most we can go on pump gas?
Stock Lt4 10.8:1
Which pump gas, regular (87) or premium (91 or 92)
In a properly built engine, 91 can get away with 12:1 without any pinging. The less spark knock you can get, the less the timing is retarded by the computer and the more power you can make. A typical engine running 91 octane should stay below 11:1. The only way to know for sure is to use a scan tool and look at the spark knocks under load.
Here in NE Ohio we have 93 at all the pumps. We can get 94 at the Shell stations, but mostly 93.
I ran 11.5:1 on my big block Olds. With the reverse cooling of the LT1/LT4 heads I figure 1 whole point above that (12.5:1) could be had.
I know there are many factors that affect detonation (cylinder pressure, cam overlap, hot spots, etc). My cam is ground on a 107 centerline, I believe this works in favor of reduced cylinder pressures due to more overlap.
Using the 0.027 head gasket will give me 0.039 quench area, and I believe optimum quench should be close to 0.035. This will yield a 12.2: cr.
An 0.040 gasket will give a quench of 0.052 and a cr of 11.1:1. This is nealy stock cr but the quench is getting further from optimum.
What's more important, optimum quench or near-stock compression?
valve closing. This has a much bigger impact on reducing dynamic cylinder pressure
compared to increased overlap.
@ 13:1 running 91 pump gas. Think my current tune is 39 degrees of advance up top, but it took a lot of playing at low rpm / high load settings.
dmaastr
9
Jul 1, 2002 02:22 PM
