supercharged 383 ci- sprayin .. whats the tricks ?
Im in the middle of a grudge match with some freinds for the fastest F-Body .. right now i have a Forged 383 ... obviously im going to need heads , diffrent Cam -- 60 ish injectors, Dual pumps .. anyone run close to this set-up now ? what parts and specs ? .,. power #'s ?
Rich
what kind of power #'s are you making ? what specific's .. i need 825 HP to take the cake (minimum)--Right now this is what i have .. 383 stroker Forged crank, Rods , diamond coated pistons .. I just cracked both heads 1000 miles into this engine doing nothing more than driving it .. the guy told me **** happens .. i wanted to kill instead i have BBB and American Express on the Guy .. so im into a rebuild -- This time correctly with the right components .. Am i close in going with CC306 cam , Trickflow heads , Holley 58mm TB (nitrous ports), ported manifold will stay 60 lb motron injectors.. what supercharger will yield the best #'s ? Where the hell do i start ? lol
In order for things to work efficiently the combo needs to be efficient. In other words things need to work well TOGETHER to maximize your efforts, otherwise your giong to leave alot lying on the table.
look into ATI prochargers
the P1SC, and D1SC are good units.You could also step it up and run the f1sc. I have a friend running a f1sc on a 04 SVT cobra with stock internals running 24PSI and hes at 822RWHP.Be sure to get a custom grind cam though
As for heads - i'd call up advanced induction or go to advancedinduction.com they have tons of people running forced induction combos with their heads and can point you in the right direction with heads/cam.
Another vote for a large, intercooled, single turbo setup (no spray).
Here's a whole page of people running FI applications (with some hp #'s and track times). Rich is even in there.
http://www.bfranker.badz28.com/fbody/supercharged.htm
Rich
