vacuum problem
Old Mar 22, 2007 | 06:20 PM
anderson1922's Avatar
Unhappy vacuum problem
I have a 330hp/350 crate motor in my 1985 truck, I installed a 625cfm Deamon carb a year ago. I recently noticed poor performance and upon ckecking for vacuum on the ported port of the carb I noticed it has little or no vacuum. I have verified the port to be open into the venturi and don't understand what may be going on or why I have no vacuum there.Any suggestions ? All help will be appreciated.
Thank you.
Old Mar 22, 2007 | 06:43 PM
LiENUS's Avatar
Thank you.
You're talking about the port that goes to the venturi? I believe that port only has vacuum at WOT. Try a port on the intake manifold or at the base of the carb, something between the intake valve and the throttle plate.
Old Mar 22, 2007 | 06:49 PM
Angelis83LT's Avatar
yea. don't use the ported port for that. thats for timed spark and it only pulls vacuum with throttle. Use a Manifold vacuum port.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
timmy39120
May 8, 2015 11:41 AM
mmf_1013
Apr 11, 2015 11:03 PM
Patrick Kovack
Mar 8, 2015 09:26 AM
Catmaigne
Dec 25, 2014 12:16 PM
