Beehive Valve Spring tests..
Old Dec 27, 2006 | 09:04 PM
Bayer-Z28's Avatar
I think I misplaced an issue of one of my Car Mags. I have, literally, a library of GMHTP, Engine Builders, Camaro Performers and just about any other mag. I'm almost sure that the test was performed an a built L98. But this can relate to ANY valvetrain build up.
I distinctly remember reading an article about a valve float test conducted with regular dual springs and Beehive springs. Not sure if they were 918 specific. I have torn my place apart looking for it. I don't think it was GMHTP, I tried Google and Hot Rod website. I cannot find it for the life of me.
If anyone has any valve spring tests, Please post them. Findings, links whatever.
Thanx..
Old Dec 27, 2006 | 10:00 PM
seawolf06's Avatar
There are several different beehive springs both from comp and other places. Comp doesn't actually make their springs, PSI does. I have some custom PSI beehives that are capable of more lift, but I set them up for more seat pressure with shims than the regular 918's.
I like the beehives because they save weight and are supposed to be a more stable spring. I think the weak link is when you want to run higher lift that .610 or so and still keep decent seat and open pressures. I'm no expert, this is just my limited knowledge speaking. I'd love to hear some expert opinions on this. I'm not sure what the lift numbers or seat pressures are, but both Lloyd Elliot and AI use the beehive springs on all their LT1 heads as advertised on their respective websites.
Old Dec 28, 2006 | 11:03 AM
Bayer-Z28's Avatar
I remember reading that the beehives reach coil bind at a different compression...... length, I guess.
The bottom of the springs stack up and it works upward from there. Isn't coil bind a deadly trait? THat's why springs break? A regular coil spring would bind all at once. The beehives bind from the bottom to the top. Suppose that's why they are more stable.
As far as the hats and locks, The regular springs are 1.44", and the BH's are 1.05". You have the same or more presure exerted on a smaller area. Tapered from 1.29" to 1.05". Obvously the smaller hat would weigh less. I forgot where I was going w/ this..
http://www.iskycams.com/2005NewProdSupp.pdf
Old Dec 29, 2006 | 10:00 AM
SStrokerAce's Avatar
Nope American Spring makes Comps springs now. Peterson Automotive Company made the beehives before hand. Not PSI.
Coil bind is when the spring is fully compressed and all the coils are stacked solid.
For the article look in Popular Hot Rodding. David Vizard has some great articles on beehives.
Bret
Old Dec 29, 2006 | 06:03 PM
seawolf06's Avatar
Bret
Oh, thanks, Bret. Sorry about that. Can you elaborate on anything he was talking about? I don't have PHR.
Old Dec 29, 2006 | 07:47 PM
89TramsAmGTA's Avatar
Here is a link to one of the Beehive Valve spring articles.
http://krcperformance.com/newcontent/beehive.html
Old Dec 29, 2006 | 07:55 PM
seawolf06's Avatar
Somewhat relevant, does anyone know the max pressure for stock style lifters?
Old Dec 31, 2006 | 04:23 PM
seawolf....
To find what the lifter is seeing take the nose pressure and mulitply that by the rocker arm ratio. Normally the stock lifters can take 450lbs, but usually the pressure isin't the problem with the lifters it's the RPM and their own mass getting in the way.
Bret
Old Jan 1, 2007 | 02:16 AM
seawolf06's Avatar
seawolf....
Bret
Open pressure = pressure on the nose?? If so, then I'm at 616lbs So I'm guessing it's not the open pressure. How do you determine the pressure on the nose? My beehives have 145 seat and 385 open.
Old Jan 1, 2007 | 10:18 PM
385 open? That's a spring rate of 400lbs/in? Dart must be using the PSI beehives at 385lbs/in rate.
Yes the open = nose pressure or the max pressure that you see with your setup. 616 is doable but high
Bret
Old Jan 1, 2007 | 11:08 PM
seawolf06's Avatar
Bret
Do you have any more info about the PSI beehives?
Old Jan 2, 2007 | 09:49 AM
Roadie's Avatar
Are you using the advertised open pressure or the pressure your setup will be running? You want to use your setup (including cam lift numbers) to come up with the real pressure...
My springs are rated at 391 lb/in and 402 lbs open. But, open is rated at .700 lift. Doing some simple math on mine (.544 lift cam) puts my actual open pressure at 341 lbs (402-((.700-.544)*391)=341). With 1.6 rockers, that's 545.6 lbs.
Old Jan 2, 2007 | 03:55 PM
Roadie hit that on the nose....
Bret
Old Jan 2, 2007 | 04:15 PM
seawolf06's Avatar
Bret
Have you ever tested those PSI springs before and have any more data on them?
Old Jan 2, 2007 | 05:50 PM
The 1500 Series PSI Beehive is 120@ 1.800" 384 lbs/in Rate, I beleive they also have a 1200 Series 130lbs@1.850" 375 lbs/in rate
Bret
R@mpage
Apr 20, 2015 10:02 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
