LT1 motor mount HELP please.
Old Sep 30, 2006 | 08:37 PM
firehawk408's Avatar
Don't know if this is the right spot for this or not. Didn't see a conversion forum.
I'm going to be putting a 95 LT1 from a Caprice into my 73 firebird. Today I found that the stationary metal mounts on the block are not square. The drivers side mount is about three inches back from the face of the block and the pass side is about 5 inches back from the face of the block. This makes the motor sit very croked in the engine bay. Are there some conversion mounts I need or do I need to grab the metal stationary mounts from an f-body. The replaceable mounts that are on the frame are new replacement units for a b-body and bolted right up to my stock 73 firebird frame. Any help would be greatly appreciated.
Old Oct 1, 2006 | 01:24 PM
OneFlyn95z28's Avatar
Re: LT1 motor mount HELP please.
they have the standard SBC mounting points as well as the LT1 mounting points it will bolt right in. The Imp. and the Vette had stock mounting points
Old Oct 4, 2006 | 06:09 AM
quickSS's Avatar
It's your passenger side mount. See the block has bosses to mount that bracket in your choice of 2 spots. The impy mounts it further back. I guess other cars mount it further forward.
So,
Take that bracket and fip it over and move it forward or back. That hopefully should work.
Karl
Old Oct 11, 2006 | 02:25 AM
unforgiven's Avatar
It is mounted further back on the passenger side for AC compressor clearance. On the LT1 B bodies they added a depression in the frame and moved the mount back for the compressor. If you are not planning on mounting the compressor in the stock location, no problem with bolting a standard small block mount in the traditional location.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
1LEThumper
Jul 14, 2003 12:45 PM
