Bearing ???
Old Jan 12, 2007 | 10:22 AM
Jlo's Avatar
Jlo
Bearing ???
Hi, guys did a search and came up empty. I'm finishing a build on my 355 LE3 engine and need the bearings, my build consist of mahle pistons, eagle H beams, and a GM forged one piece crank cut at 10 on the low side. My Q is what bearing do you all recomend I'm looking at the Speed Pro Competition series bearings with the H14 overlay, Just wanted to know what you all think which bearings would be good Speed Pro Competition series or the Clevite H bearings
Old Jan 14, 2007 | 05:06 PM
oil pan 4's Avatar
I have used federal mogal (Speed Pro) brand connecting rod and main bearings.
They worked perfect, after my drive way engine over haul on my diesel my oil pressure is up a bit form 10psi hot at idel. Now it never drops below 25psi.
$110 well spent.
Old Jan 14, 2007 | 05:26 PM
rskrause's Avatar
Moderator
Both are fine.
Rich
Old Jan 14, 2007 | 05:36 PM
Steve in Seattle's Avatar
VRE's making my 396 with Dart coated bearings.
Heard good things about the Calico coated Clevite bearings as well.
Go coated... it's a cheap upgrade and probably worth the insurance.
Old Jan 14, 2007 | 06:22 PM
hotrod18_69's Avatar
Do you have to have any extra clearence on the crank for the coated bearings. I have a friend tell me i had to have .01 extra cut into the crank for coated bearings. I have never heard this before.
Old Jan 14, 2007 | 09:02 PM
I've never heard that... could depend on the coating I'd guess... I'd give the manufacturer a call to find out.
Old Jan 14, 2007 | 09:29 PM
Jlo's Avatar
Jlo
I was thinking of coated but they are kinda expensive that's why I was thinking of going with speed pro comp series or the H bearings. Looks like I'm gonna tryout the speed pro.
Old Jan 15, 2007 | 09:33 AM
oil pan 4's Avatar
Just assemble them with GM E.O.S. assembly lube.
PN#: 1052367 I think it was $8 for a 16oz can.
I covered all my bearings with it, filled the oil pump/main cap up with it before slaping it back on and put some in the oil filter.
I should all so tell you that I reused the old oil pump and still gained all that pressure.
Some people are starting to turn away form moly assembly lubes, because the moly is super hard and is some what abrasive.
Plus it clogs the oil filter.
Put those 2 together and you could have a very expensive "oh shix".
Old Jan 26, 2007 | 06:17 PM
Jlo's Avatar
Jlo
Just to update you guys, Summit didn't recomend the H series for me so I went with the Clevite P series for both rods and mains and the Dura bond hi perf. for the cam. What do you guy's think?? they told me that the H were for aftermarket crank.
Old Jan 26, 2007 | 08:38 PM
oil pan 4's Avatar
Yea no one uses those H series, I guess thats why.
Advise, using the best most highly recomended cam bearings you can get. I have herd that some times they can spin out like a rod bearing.
Old Jan 26, 2007 | 08:42 PM
rskrause's Avatar
Moderator
Depends on how they cut the crank. If they left or ground in a large chamfer, you need the "H" bearing.
Rich
Old Jan 26, 2007 | 08:49 PM
Jlo's Avatar
Jlo
Rich
Well it's a stock gm forged unit cut at .10 on the low side. whatever that means??
Old Jan 26, 2007 | 08:55 PM
rskrause's Avatar
Moderator
You need to get someone who knows motors to look at the fillet area. Any machine shop will do.
Rich
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
