Cylinder Wall question
Old Mar 7, 2007 | 06:51 PM
94_camm's Avatar
Ok i had a piece of small almuinum that got wedged in between the piston and cylinder wall.it made a small impression in the wall.will this effect anything?Motor is a 383 with zero miles on it!
Old Mar 7, 2007 | 07:15 PM
cnorton's Avatar
In the area of ring travel or below it?
Old Mar 7, 2007 | 08:42 PM
engineermike's Avatar
Can you give approximate dimensions of the flaw? It can actually take much more than most people think.
Mike
Old Mar 7, 2007 | 09:30 PM
94_camm's Avatar
Bout an inch long..if you took a pen and drew a line on a piece of paper thats wat it looks like..its in the travel of the pistons yes i mean its not a big piece is missing just like a little scartch!
Old Mar 7, 2007 | 10:45 PM
MachinistOne's Avatar
The aluminum made a scratch in your bore??? sure it wasn't a piece of steel?
Can you catch your fingernail on it?
Old Mar 8, 2007 | 04:25 AM
If it were me, I'd run some fine grit sandpaper over it to make sure there isn't a high spot, and run it.
Old Mar 8, 2007 | 06:20 AM
Paulster2's Avatar
If it were aluminum, I would bet that it left material behind instead of scratching the bore. Fingernail test is a good idea. If it truely is a scratch, having it rehoned might not be a bad idea to clean it up. It might take one to two passes to do that. You might want to check the piston/rings for damage, too.
Magenta_Hearts
Mar 29, 2017 08:54 PM
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Hurin
Dec 13, 2014 07:38 PM
redzed
Sep 4, 2002 06:22 PM
