Adding on to a fuel tank..
Old Dec 6, 2006 | 09:53 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
and not just a sump! anybody tried actually making a tank larger, changing size, etc. I am in need of a larger tank for a race car, and the factory tank is very odd shaped, and having a cell made to fit is going to be very tough. I did the solid model of it, and it has a ridiculous number of pieces- so I just want to add a small portion on to the stock tank
thanks!
Old Dec 7, 2006 | 09:23 AM
The Big Show's Avatar
thanks!
Have you checked out Jay Billingsly? I know he use to sell a nice aftermarket piece that I was actually gonna buy a few years ago.
Old Dec 7, 2006 | 10:50 AM
jerminator96's Avatar
What's the tank made out of?
I don't really see the problem, you could weld on some fittings and just add another smaller tank. Attach a couple of lines in between the 2 tanks and position the second tank somewhere in the lower middle of the first. You have to make sure that it is low enough to be filled completely but high enough that it isn't storing fuel when your primary tank is about to run out.
Maybe it's more complicated than that on a racecar, rules being what they are, but that is how I would do it.
Jeremy
Old Dec 7, 2006 | 10:56 AM
Z28SORR's Avatar
A couple of possible problems. Don't see how you are going to be able to add enough volume by welding to an existing tank. And then of course you have to weld to the fuel tank, which can be hazardous to your health.
On my 84 I dropped the stock tank and cut out the trunk/storage area behind the axle and installed a 30gal. fuel safe cell there, aka NASCAR style. It's really a nice install. However if you don't wish to cut up your car you could easily ad an auxilary cell and pump in the storage area. When your tank gets low fip a switch and pump from the aux tank. I would use it to simply refill my stock tank, but you could plumb it into the fuel system too.
Old Dec 8, 2006 | 05:26 PM
i cant cut the unibody(rules).
I went ahead and decided to go with a custom cell with a bladder for safety. I have it drawn up in solid works and am going to verify physical fitment with a project board model, and then send it off to fuel safe to be built.
Old Dec 8, 2006 | 05:50 PM
byrons1502's Avatar
try i believe rock valley they custom make tanks for custom and stock apps
Old Dec 8, 2006 | 06:07 PM
FASTFATBOY's Avatar
Summit makes a fuel cell that will fit right in the well in the rear of our cars, plumb it to fill into the factory tank.
David
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Cam's maro
Jan 30, 2015 09:21 PM
