Motor plates or solid engine mounts
Old Oct 13, 2006 | 08:39 AM
Lisa33's Avatar
Should place oure SC LT1 in a tube chassie car till next year, we have a engine plate beetween the engine and trans but it looks like it will be BIG trouble to fit a motor plate in the front beacuse of the headunit.
So the Qs
Is it any risks to run solid mounts using the 4 bolt holes ont each side of the block and down to the frame? (have herd storrys/romours about block cracking beacuse of solid mounts)
Or should i fabricate some type of poly mounts for it?
Planing to make a poly/rubber mount to the tranny.
ake e
Old Oct 13, 2006 | 05:43 PM
HeadDoctor's Avatar
Re: Motor plates or solid engine mounts
Lisa33
Need detailed pictures to help you out
Denny Schmidt
Old Oct 14, 2006 | 05:37 PM
Lisa33's Avatar
Not so detailed
The easiest way to install the engine would be widh a rear engine plate between trans and motor (bolted to chassie) and a plates thats bolted to the engine like in this pic.
Would this be OK or do i risk that the block brakes if i weld the front mounts to the framerails? or should i make some kind of poly mount to absorb vibrations?
Old Oct 15, 2006 | 09:28 AM
v7guy's Avatar
Is the block cracking a legitiment concearn with solid mounts?
Old Oct 16, 2006 | 02:07 PM
Lisa33's Avatar
Not sure, was hoping to get some answers.
HectorM52
Jul 30, 2017 11:46 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Omega9
Aug 2, 2002 12:33 AM
guionM
14
Jun 19, 2002 08:30 AM
