motor locked
Old Mar 19, 2007 | 11:11 PM
jamilz28's Avatar
motor locked
the motor wont turn over and i tried to turn it by hand and it didnt work
it happened after i rolled the truck on its side and there is like barely any body damage but the motor is locked do i have to rebuild? or is it fixable?
Old Mar 19, 2007 | 11:34 PM
Roadie's Avatar
it's probably hydro-locked. pull all the spark plugs and clear the cylinders with the starter. Definitely change oil before actually starting it.
Old Mar 19, 2007 | 11:45 PM
jamilz28's Avatar
what do u mean by clearing the cylinders with the starter
Old Mar 20, 2007 | 12:04 AM
Alan Namsa's Avatar
Water is not compressible, unlike the air-fuel mixture that produces power. So, any water in the cylinder would prevent the crank from turning. Pull the spark plugs out and then try to turn the engine over. The speed of the engine with no spark plugs will blow much of the offending liquid out of the cylinder, unlike hand cranking it.
If you rolled it on its side, the engine may have run long enough to seize bearings. You can also bend rods and valves when an engine is locked up from water in the cylinder.
Good luck, you will need it.
Old Mar 20, 2007 | 12:22 AM
LiENUS's Avatar
Just a note, if he rolled its as likely to be water as it is to be oil. which is still uncompressible
Old Mar 20, 2007 | 12:25 AM
jamilz28's Avatar
if the motor needs to be rebuilt i am gonna so be screwed cuz i just replaced the trans
Old Mar 20, 2007 | 12:37 AM
Alan Namsa's Avatar
I would file a lawsuit against the people who gave you a license and claim everything as direct effects of their negligence. Also ask for 5,000 dollars in punitive damages.
Yes, and the term is actually incompressible, for future reference.
Old Mar 20, 2007 | 12:49 AM
jamilz28's Avatar
i should sue ford for my brakes failing on the highway making me run into the wheel of a dump truck which griped my bumper and fliped the truck over
Old Mar 20, 2007 | 10:34 PM
jamilz28's Avatar
yep now i have to go shopping for a motor its done
Old Mar 21, 2007 | 08:15 PM
Kevin Blown 95 TA's Avatar
You live in Oklahoma? You should have it towed to a mobile home park and wait a couple weeks for the first tornado to come along, then claim it on comprehensive damage.
Old Mar 22, 2007 | 01:56 PM
jamilz28's Avatar
idk where mobile home parks are and its not full insurance
guruerror
Dec 12, 2020 06:32 PM
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
capebuf
Jan 13, 2015 07:22 PM
