Help Please?
Old Feb 12, 2007 | 07:00 PM
89_Irocz's Avatar
Help Please?
What do I need to do to use this engine linked below, in a carb car. (82Olds) I think we are going to have fuel pump problems. http://paceperformance.com/index.asp...D&ProdID=17668
Old Feb 12, 2007 | 07:12 PM
mdacton's Avatar
you would need an electric pump and regulator for a carb. summit has the kits for $220 with all the fittings and everything....
Old Feb 12, 2007 | 10:47 PM
89_Irocz's Avatar
i was told that i may be able to just change cams.
Old Feb 12, 2007 | 10:48 PM
mdacton's Avatar
for what?
ther is no hole in the block for a fuel pump pushrod..all cam have the essentric for the pump.....
Old Feb 13, 2007 | 04:42 AM
89_Irocz's Avatar
theres a hole there...the engine is a LO5 (350 TBI)witch come in a 87-95 chevy truck
Old Feb 13, 2007 | 08:55 AM
mdacton's Avatar
when I read that link it says no provisions for mechanical pump on that motor
They stopped casting it in there in 1987, everything went EFI then
Old Feb 13, 2007 | 04:40 PM
89_Irocz's Avatar
ok!!
Old Feb 13, 2007 | 10:26 PM
confused327's Avatar
my L98 block has the mech. pump casting.
and in that picture it has the casting too.
Old Feb 15, 2007 | 01:49 PM
mdacton's Avatar
it is cast on there...there is no HOLE for the pump pushrod....."I THINK" I DO NOT KNOW why not call the people selling it
Old Feb 15, 2007 | 02:48 PM
the best bet would be to call them. my L98 does have the pushrod hole too.
