NHRA Top Fuel blower belts
Old Aug 6, 2006 | 04:29 PM
Steve in Seattle's Avatar
Post NHRA Top Fuel blower belts
Interesting article on NHRA Top Fuel and Funny Car blower belts.
http://www.gates.com/brochure.cfm?br...ocation_id=557
Originally Posted by Gates Corporation
When the belt is installed and aligned on the crankshaft–blower drive, there is a margin of error of 1/4° ... But the biggest “belt-eater” ... results from “pedaling.”
This normally occurs within 300 feet from the starting line, when the drive feels the rear tires begin to slip and they smoke up the track. The engine crankshaft is accelerating from 9,000 to 11,000 rpm, and then when the driver lets up on the gas, it slows to 2,000 rpm.
At the same time, the blower is accelerating and building up inertia. The engine and the blower are working against each other, and the belt breaks from the force of stress and the two opposing speeds.
Not sure if this qualifies as Advanced "Tech", but it's interesting and didn't really fit in other forum.
One more: http://www.gates.com/brochure.cfm?br...ocation_id=548
Interesting stuff when you consider that belt is used to drive a 60+psi blower that eats up HUNDREDS of ponies on a 7000+ hp engine.
The crankshaft numbers quoted in the article must be old however... I was under the impression that NHRA now limits the fuelers to 8400rpms via a MSD ignition.
Old Aug 6, 2006 | 05:09 PM
TransAm396's Avatar
Re: NHRA Top Fuel blower belts
cool
Old Aug 6, 2006 | 06:36 PM
lol... essientally you "engine brake" a belt to oblivion.
Old Aug 6, 2006 | 08:57 PM
Stephen 87 IROC's Avatar
An engine making over 7000 hp and it takes about 500 hp just to spin the blower.
Old Aug 7, 2006 | 02:16 PM
markinkc69z's Avatar
Its a couple more ponies than that....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
siguy
Nov 27, 2014 10:07 AM
