re-torquing head bolts...
Old Dec 20, 2006 | 12:12 AM
Roadie's Avatar
The SCE ICS Titan head gaskets say to re-torque the head bolts after a heat cycle, in order, one at a time... It says to break the friction contact and re-torque to specs. I have one question with 2 parts...
On the head bolts where I used thread sealant, will this:
1) create a coolant leak, and/or
2) cause problems with achieving the correct torque spec (While wet ARP thread sealant acts just like moly lube for torque-ing(sp), dry stuff probably binds up and gives a false torque reading...)
$.01 for your thoughts?
Old Dec 20, 2006 | 12:36 AM
MachinistOne's Avatar
The dry stuff would mess up the torque and maybe leak, I always use permatex #2 non-hardening sealer so honestly I don't know about other sealants in that situation. Also if I am using titan gaskets, I have already changed over to head studs, so no loosening of the sealing part is necessary.
Old Dec 20, 2006 | 01:03 AM
Roadie's Avatar
hmm. Looks like the ARP stuff doesn't harden either, but I found a few leak stories... It's too late to go back now, so wish me luck on it.
Old Dec 22, 2006 | 11:37 PM
Mkos1980's Avatar
I ended up re-torquing my headbolts using the arp stuff. NO leaks so far and about 6000 miles on motor and still perfect. I didnt get much more turn on the lower bolts but the longer ones i got about another 1/4-1/2 turn on them.
Old Dec 29, 2006 | 10:41 AM
Kevin Blown 95 TA's Avatar
I'm sure it gets harder over time, but in the context of break-in and cooldown periods, I'd be surprised if the retorquing process could cause a leak. I just wouldn't back them up very far and possibley break a seal before retightening. Studs makes this less of a problem (if you use the sealer).
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
