SOmeone please check my math
Old Nov 1, 2006 | 07:21 PM
wicked_95z's Avatar
Alright, 918 beehive springs coil bind @ 1.140". Now if the springs are installed @ 1.740" with a .628" lift cam at max lift the spring is compressed to 1.112" which is .028" lower than coil bind. If I install these springs @ 1.800" that will put me at about .032" above coil bind. Is this right??
Old Nov 2, 2006 | 04:05 AM
sssalah's Avatar
That's right, 0.628" lift is too much for the beehives. Also boosted motors need harder springs.
Old Nov 2, 2006 | 04:49 AM
wicked_95z's Avatar
What if I get a new set of the 918s and set them up at 1.800" instead?
Old Nov 2, 2006 | 11:24 AM
arcticz28the383's Avatar
My 918's are set up at 1.8" and they work fine, but my cam is .555, .570. I have heard ppl say to not go over .600" lift with beehives.
Old Nov 2, 2006 | 01:45 PM
markinkc69z's Avatar
Comp specs those springs at 1.800 installed height and 130#.
They list open pressure as 333 @1.150 or .650 lift.
Your .628 is within its range. Run them as they suggest @ 1.800.
Old Nov 2, 2006 | 04:15 PM
I think ppl say to not go over .600 not because of coil bind, but because of the fact that valve float may be more of an issue at higher rpms. Thats why they make stiffer springs with a higher closed seat pressures so that the valves will close faster at higher rpms. I've never ran an engine with beehives over .600, but maybe someone else has?
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
