Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
5.3 injectors in a lt1
Old Apr 17, 2012 | 06:12 AM
Stephen G's Avatar
does anyone know if some 5.3 injectors from a silverado will work in a lt1?
I bought some cheep lt1 injectors from ebay and they are noticeably shorter then stock and leak when i put them in.
I do have a 5.3 silverado im going to be scraping out and was wondering if i could rob the injectors from it.
Thank You
Steve
Old Apr 17, 2012 | 06:19 AM
96capricemgr's Avatar
Re: 5.3 injectors in a lt1
They are probably lower flow, sure a 5.3L makes more power than a LT1 BUT they also run 58psi fuel pressure instead of 43.5.
I believe the wiring is different too.
If you need a set of stock LT1 injectors just post in the wanted section a lot of us have them laying around.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
