Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Running lean
Old Apr 25, 2012 | 07:50 PM
kartracer13's Avatar
Running lean
98 LS1 running lean. My qustion is two fold,
1) When I turn the ign. to the on position there is no gas getting to the fuel rails. Could that be a bad fuel pump and give me the lean codes? I've looked at just about everything else.
2) What the hell is the vacuum hose at the pass. side,bottom of the throttle body?
Thanks for any help.
Old Apr 25, 2012 | 08:50 PM
mrmint69's Avatar
Re: Running lean
Have you replaced the fuel filter lately? Can you hear the pump running, when you turn the key on? If you have no fuel pressure at the rails, it can only be a couple things. If you had no fuel getting to the fuel rails, the car would not run.
Old Apr 25, 2012 | 09:15 PM
Re: Running lean
Yes,I've repalced the fuel filter and the fuel presure reg. on the fuel rail. The pump runs right at first like normal,but no fuel gets to the rails. I turn it over a couple of times then let off and turn it over again and then it starts and has fuel presure. I know I need to get a gage to see what the presure is but I haven't yet.
Old Apr 26, 2012 | 08:02 AM
mrmint69's Avatar
Re: Running lean
Also check the fuel pressure while driving. Maybe the pump is starting to dye and will allow it to start, but can't keep up with normal to wot driving. Also make sure it hold pressure for a few minutes after shutting down.
Old Apr 26, 2012 | 11:16 AM
Re: Running lean
I took it back to the shop that put the fuel pump in and had them test it and what do you know,it had only 30psi. So,luck would have it that it's still under warranty,so they are fixing it right now.
Old Apr 26, 2012 | 01:55 PM
mrmint69's Avatar
Re: Running lean
Cool. Gald this will not cost you anything!
grabbem88
Feb 13, 2015 03:09 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
TechCam97
Sep 12, 2002 07:20 PM
