Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
No power to anything.
Old Oct 17, 2012 | 09:32 AM
DTPZ28's Avatar
She died on me at sonic last week, no power to anything. Minus windows radio and headlights. Replaced ignition cylinder, to no avail. Bought a new ignition switch but I don't want to pull the whole column to replace it. How would I go about wiring in a push button that doesn't need the key in the cylinder? I know how to bypass vats, so no worries there. I just wanna get back out on the road. Walking to work sucks. Thanks guys.
Old Oct 17, 2012 | 10:31 AM
mrmint69's Avatar
Re: No power to anything.
Important to know what kind of vehicle. Anything done to it like aftermarket security system.
Old Oct 17, 2012 | 04:16 PM
DTPZ28's Avatar
94 z28. Bone stock.
Old Oct 18, 2012 | 12:22 AM
mrmint69's Avatar
Any codes? Believe the pcm will shut down certain things and will set a code.
Old Oct 18, 2012 | 07:03 AM
Whole lot easier just to replace the ignition switch. You don't have to pull the column, if you don't want to.
Old Oct 18, 2012 | 08:12 AM
DTPZ28's Avatar
Can't tell if its throwing a code or not. No fuel pump prime, no dummy lights nothing. I turn the key and it just clicks.
Old Oct 18, 2012 | 12:10 PM
You have to scan the PCM for codes. There are codes that can shut the engine down but do not turn on the SES light. But this doesn't sound much like a "code" problem. Sounds like a wiring or switch problem.
Old Oct 18, 2012 | 12:39 PM
DTPZ28's Avatar
Thanks to shoebox, hopefully I can get the switch replaced tonight. Key word hopefully.
Heathen1
Jan 2, 2016 04:27 PM
guruerror
Jun 9, 2015 07:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
