Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pump help
Old Dec 13, 2011 | 05:47 PM
undecidedfbody's Avatar
Fuel pump help
Hey guys this is a question about If my fuel pump is good enough
I had bought the car with a fresh 190lph fuel pump, will this support what I have done
Ai 200cc heads and intake
383 stroker
42lb racetronix injectors
Holley afpr
Ai custom cam
11.9 compression
Old Dec 14, 2011 | 03:52 PM
Re: Fuel pump help
There are a lot of variables involved, so you have to make assumptions:
-Brake specific fuel consumption (assume BSFC = 0.483 #/HR/HP)
-Fuel specific gravity (assume 0.72 SG = 6.0 #/Gal)
-Return to tank (assume 20%)
If you make these assumptions, multiply estimated flywheel HP x 0.38 to get the minimum pump size in liters/hour.
Example: 500 flywheel HP x 0.38 = 190 LPH
As you can see, you are marginal on fuel pump and if you expect more than 500 flywheel HP you need more pump. Or if you have a very efficient combustion chamber and a very good tune, you might approach 0.45 BSFC and you could make 540 flywheel HP with the 190 LPH pump. Make sure the pump is flow rated at 190 LPH when operating at 43.5psi, and that is where you are running your fuel system.
My recommendation, from looking at the limited specs you listed, would be that you need a larger pump.
Old Dec 15, 2011 | 03:58 PM
Re: Fuel pump help
Yep I am going to go with the racetronix fuel pump kit
Thanks for all the help
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
