View Full Version : Wheels and Tires
- What Rear Tires for a 500hp Car
- Rotation question...
- z06's + 335 hoosiers with flared fenders
- 17 X 11" Rims
- Zr1's-Tire Size
- stock wheel specs?
- C5 Corvette wheel caps
- Kudos for FAQ
- got my new wheels put on(pics inside)
- gold wheels on a black trans am?
- not satisfied with 275 35 18's
- Stupid offset question
- will these wheels fit my ride??
- Slick v.s Homemade Slick (dumb question)
- WTT 17x11 36mm offset chrome ZR1 for 50mm offset
- anybody have some pics of black zr1 rims?
- what tires for these rims...
- Pics of Weld Draglites and Pro Stars on 4th gens
- Can someone do a photochop?
- cheap gator back tires
- 315's
- Kumho Ecsta MX
- 3rd gen diff in a 4th gen, need help with wheels
- nice site but $$$$$
- ? on zo6 rims with 1.75" drop
- Widest Tires
- Weld Pro-Star 15x5 with 3.5"bs or 15x6 with 3.5"bs
- vredestein tires
- OEM ZR-1 How much
- ZR1's are back in my life
- Bolt pattern Question
- who has polished ZR1s?
- anyone deal with
- 15 x 8 offset question
- What should i set my tire pressure at?
- Stickiest street tires
- M&H 325/45-17 DOT's fit
- Turquthrust II's $99....
- just got a good deal on a second set of telstars
- Black Z06's on Mystic Teal '97?
- where can i find black zo6s W/O STUDS
- got my TT2s wheels w/pic
- 20x10 35 offset?
- Drag wheels for a third gen, what offset?
- 1st and 2nd wheels on 3rd gen
- explain: How 92's paint 16" rims on stock 91's?
- white camaro's!!
- fit or no?
- anyone know if the C5 Z06 front brakes will fit a 17" dagger wheel
- will this fit?
- RIMS and TIRES
- Z06 center caps
- pix of Z06 motorsports inside
- Wheels for my 30th Anniv. 'Vert
- wheels with deep lip
- jus checked my back spacing
- Ordered Rims What size tire is recommended??
- ZR1 wheels
- Tires for 15x3.5 Prostar
- Wheel Stud Q
- 17x8 with 20mm offset?
- Re-Chromeing?Black Chrome?
- Ok i need new tires, which kind should i get?
- Merry Christmas to me.
- Tires, Non-Directional Semi-Performance.
- Help?!?
- wheel RIM'S Are these??? HELP
- got the ZR1 wheels on
- What wheel setup for my '96 SS?
- C5 Rims On 02 Firebird?
- Looking like time for new tires (Possibly wheels), Any input on my options
- What is your favorite wheel design that fits on a 4th gen?
- Anyone modify there wheel wells to accept larger rims?
- Anyone dealt with this company?
- torque on draglite wheels?
- ET Streets for Prostars..
- The see Through Tire....
- 18's in front 20's in rear?
- wheels for 78 camaro
- Poll: Torq Thrust IIs, ZR-1s or OEM 16s on a red '91 RS???
- How can you tell GM ZR1's from aftermarket?
- 15" wheels
- offset question
- welds draglites what tire?
- anyone have firestone fuzion zri's?
- 3 1/2 " Front Wheels
- Change wheels?
- How much for Prostars??
- new Zr1s wrong lug nuts?
- testing air pressure sensors
- If I move up to 17in wheels, will my speedometer be off?
- rubbing
- 225-70-16 tires on factory 5 star firebird wheels?
- Tire Rot - Do these tires look OK?
- Best street tire?
- Cheap Rims
- Quasar blue LT1 Z28 with grandsport wheels? Searched... all I found was dead links.
- Wheel options
- Will 245/45/17 fit in the front?
- wheels and tires
- Looking for Bogarts
- m/t's dr's for third gen
- what size tires on my z28??
- wanting black Zr1
- Anyone know the weight of this wheel?
- Best 15 tire to run without tubes?
- Wheel Choices for Burgundy 94 Z'
- 19" x 8" => 245 tires ???
- C6 Z06 wheels black w/ machine lip..
- Need help with wheels
- 77 camaro TTII help please ????
- Foose Nitrous wheels
- What about Martin Bros ???
- can i fit 335/30/18 in the back???
- OEM Wheels
- whos running ARE Le Mans wheels
- looking for company to mill down my wheels
- my Z with bullet wheels
- Nitto: NT-01 vs 555R II
- Storing Wheels for the winter
- Lug nuts for my welds? Will these work?
- new tires for less than $300!
- Want to Get My Wheels Repaired and Chromed
- LG World Challenger Wheels
- Boyd Coddington Fury Wheels
- Best Street Tires
- Just picked up a set of Goodyear F1's...
- Essenza Evo-Z tires
- TTM's on a red Camaro
- Picked up some GM 10-spokes
- Any Thoughts on Kumho Ecsta ASX Tires?
- wheel need re-balancing or alignment
- What tires should I run LE2
- Question for you guys
- everyone with 11" zr1 and sportlines or lower come in!
- Ss Wheels
- Maybe wrong forum, but C6 Wheels on a C4 Vette?
- 15" wheels on a 4th gen
- How do these look on my 93 Formula
- Purchased new shoes for my SS (TT2's)
- Finally my TT2's are on...
- looking for pics of zo6 wheels with MT DR
- Which tires should I buy? *SLICKS*
- Will These Fit My 94 Z28
- 285 30 18???
- Will A 18x10.5 With A 58 Offset Fit My 94 Z??
- pics of c6 zo6 wheels on camaro
- Okay Price??
- Re-finishing the inside of my chrome y2ks
- need help with tire sizes
- Thickest spacers I can use on rear wheels?
- Which slicks to get?
- Clearance on 3.5" Prostars?
- Lost key
- Another special from DTD
- Will a tire patch override your speed rating?
- To those of you running 15x3.5" skinny up front
- Best DR for an 18 inch wheel, opinions needed...
- Painting chrome wheels?
- 20x9 for the front and 20x10.5 for rear???????
- How can I remove powdercoating?
- What do you use
- Any good DR's to fit a 17x11 rim and be friendly to 600-650rw?
- DD Drag Radials. M/T or Nitto?
- 3 Tires are 275/40/17 one is 255/40/17 will it matter?
- white wheels
- 17" 11" ZR! rims, make it or break it.
- Winter driveing technique.
- Toyo Proxes 4 or Pirelli P Zero Nero M+S???
- C5 Vette Rims, will they fit?
- Z06 Wheels on formula?
- 345/30/18's
- best looking wheels on a pewter camaro, chrome or black? post pics!
- New Wheels
- Discount Tire Direct - Please read
- 275's on it now...can I go wider?
- biggest slick for a 4th gen
- Special pricing from Discount Tire Direct
- How LOW should she go???
- Best offset to use with lowered Camaro
- Taking Off Lug From Stripped Stud!
- 19's in back 18's in front????
- Should I get these wheels?
- Any trouble with 275/50/15 on a 15x10 wheel?
- In your best experience, best rain/snow tire?
- 4th gen wheels on 3rd gen ?
- Widest wheels/tires for 2nd gen?
- Smallest wheel/tire that would fit?
- Which drag radial on 18" rim?
- tires cupping
- weld prostar XP 15 inch
- Wont Fit?
- Need new tires
- Anyone running BF Goodrich G-Force T/A KDW's?
- What are the OEM wheels for '96 Camaro SS
- snow tires and steel rims...
- 17x9 ss 5 spoke and 17x11?and tire ?
- Will an 18x8.5 rim with a +20 offset fit
- FRONT 17x9.5 REAR 18x10.5 WHATS THE BEST TIRES AND SIZES FOR THESE??
- Could see pics of Z06 rims on car
- SSR Integral Wheels on a Camaro
- 17x9.5 Z06 Wheels
- Need some help with rear welds 15x10
- trying to get rims, currently in iraq
- 30th ann wheels ( poll )
- SilverRam gets a new set of shoes(BOGARTS), Pics !
- pics of new zo6 style on 4th gens?
- Where Can I Find Gunmetal Z06 wheels
- SS Wheels
- American Racing Trakstars
- M.T. Drag radials:
- Where to buy Bogart wheels??
- 15 by whats up front??
- need tires and need questions answered
- 17x11/ 315-35-17 rears ok?
- Want these wheels, can't make sense of FAQ, help?
- tire size question
- Sumitomo tires?
- 1995-1999 Z28
- what do you guys think?
- Chrome ss wheels!!
- 13" inch
- Will THESE fit..?
- what offset?
- Ruff Racing Wheels anyone?
- Z06's on 93-97 Formula
- will these fit?
- What choices for tires do I have for these sizes?
- 17x9 SS rim/tire combo question
- What is the best size tire for 17x11 rim
- What size wheels in attached pics?
- Dayton Daytona ZR's?
- 18" ZR1 wheels
- 275/50/15 on 15 x 10
- 15in Rims
- Recomend me soem D/R's... and maybe some drag wheels...
- Drag Radial Questions
- 10.5-11 Y2k Vette wheels
- anyone have these?????
- 15x10
- widest tire/wheel combo front and back??
- Ok maybe a stupid question but
- Color of 06 Gumental Vette Wheels?
- Maybe a newb ? but are all ZR tires Z-Rated?
- Quick opinion
- Storing tires... what is the proper way?
- cheapest skinnies
- Someone please help me find some A/S tires
- 16 and 17?
- Zr1's Replicas... do slp center caps fit into replicas?
