rubbing
Old Nov 25, 2006 | 02:20 PM
CLEAR's Avatar
rubbing
my 95 t/a has 17x9.5 vette rims with 275/40/17 tires. when i cut the wheel the all the way the tires rub the front of the fender liner. anyone else have this problem and what did you do? i can push the liner in some and it wont touch but keeping it pushed in is the problem. i dont understand since ive got stock sizing.
Old Nov 26, 2006 | 10:42 AM
What is the offset on the wheels?
Old Nov 26, 2006 | 05:43 PM
CLEAR's Avatar
im not sure. they are zr1s. they do look like they stick out a little past the fender though. tomorrow i will be putting z06 wheels on and they may change how they sit. ill post again tomorrow evening when i find out of the new rims rub.
Old Nov 26, 2006 | 09:03 PM
There are two different 17x9.5" ZR1 wheels. 56mm is the one you want. The 37.5mm wheels will stick out past the front fender and may rub, as you have discovered.
What Z06 wheels are you using? Many of the factory wheels have excessive offsets that put the wheel deep in the wheel well on an F-Body.
Old Nov 26, 2006 | 09:15 PM
CLEAR's Avatar
i got the z06 motorsports wheels made by oe concepts from tomzwheels.com i dont know the offset. they didnt tell me however they did ask what car im putting them on. i didnt know the zr1s came in 2 offsets. geez im nervous now about what ill be receiving tomorrow. what offset do you think ill be getting and why do zr1s come in 2 offsets? thanks
Old Nov 28, 2006 | 08:53 AM
teke184's Avatar
i suggest doing some research prior to purchasing stuff like that.
even if they "tech guy" says it will fit.
would have saved you some trouble
Old Nov 28, 2006 | 09:30 AM
The ZR1's come in two different offsets because they were used on two different Corvettes. The original ZR1 wheels had the smaller offsets, meaning they stuck out further, but the ZR1 Corvette had wider bodywork/fenders than other C4's, to cover the tires. In 1996, they wanted to use the ZR1 wheels on the 1996 Grand Sport, but without the wider bodywork. So they increased the offset of the ZR1 wheels to tuck them under the stock C4 bodywork. Even with that, the rear ZR1/Grand Sport wheels stuck out far enough that they had top put a glue-on "eyebrow" on the rear fender to meet regulations regarding tire coverage.
2QUIK6
Sep 17, 2016 02:31 PM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
colts0455
13
Aug 7, 2015 09:15 PM
ModdedNerd
Dec 25, 2014 05:51 PM
sandmanljs
Jul 6, 2002 08:25 PM
