jus checked my back spacing
Old Dec 15, 2006 | 06:08 PM
Misfits's Avatar
Unhappy jus checked my back spacing
i jus measured my back spacing off my 2 18x9.5 chrome y2k rims and it came close to 7.8inches. i measured from hub mounting surface to the inner fender of the wheel (the inner lip). i believe that means it is a +65mm offset???
I need to order 2 more rims and they will be +54mm offset. What can i do with the +65mm rims? is there any remedy? should i put them in the back or front?
I hope there not useless .. my car is a 97 z28 with sportlines. i bought the car like this (the springs r blue) also has the stock decarbon shocks.
Old Dec 15, 2006 | 07:16 PM
Take the published width of the wheel. Add 1" to that number. Subtract the backspace from that result. Multiply that number by 25.4. That is the offset in millimeters.
9.5 + 1.0 = 10.5
10.5 - 7.8" BS = 2.7"
2.7" X 25.4 = 68.6mm.
The trick is accurately measuring the width of the flange that hold the tire bead on the wheel. It can be less than 1/2" (that's where the "add 1" comes from..... 2 X 1/2" - 1.0"). If your flange width was 0.43", your backspace would be 65mm.
Using a 7/16" spacer on the 65mm wheels would make them identical to 54mm wheels.
Old Dec 16, 2006 | 12:29 PM
Misfits's Avatar
9.5 + 1.0 = 10.5
lots of math lol.. but if i go ahead and use the spacer, should i use the spacers in the front or back?
I measured that flange, it seems pretty darn close to .5inch.do different wheels have different flanges? mind you that these are jus ordinary Y2K rims.
Old Dec 16, 2006 | 02:32 PM
Yes, the width of the bead retention flange is not "standardized", but 1/2" is generally close enough.
I don't like spacers at all. Its sort of a crap shoot whether you want them on the front with the higher weight, braking and cornering loads or the rear with the high shear loads under acceleration and braking.
And, wherever you put them, you will need longer studs.
Old Dec 16, 2006 | 04:02 PM
Misfits's Avatar
damn man, this just keeps gettin worse. how short well my studs be if i jus added the spacer and the lug nuts?
if i did get longer wheel studs, what size do you reccomend? i jus did a yahoo search and i've seen 10mm and 12mm studs.. and i read sumthing that my center caps wont fit unless i poked holes through them for the studs.
Old Dec 16, 2006 | 08:03 PM
Misfits's Avatar
ok I think i came up with another plan.
Keep the +65m rims and put them in the rear, and buy 2 17x8.5 Y2K's in the front. but trouble is i read the FAQ's and I need a +35 to 44mm offset. The only ones I can find on ebay and directtire.com are +56mm offset.. arrgh
WildRidez
Jan 16, 2015 03:10 PM
squarehead
Jan 15, 2015 07:02 PM
Jan 13, 2015 09:52 PM
Snoman73
Nov 17, 2014 07:22 PM
danielbmx
Aug 27, 2002 11:11 PM
