Zr1's Replicas... do slp center caps fit into replicas?
Just wondering if the ZR1 center caps made by SLP fit into the ZR1 replica wheels. Also whats the widest tire size that 9.5" ZR1's can fit on? 275 or more?
Re: Zr1's Replicas... do slp center caps fit into replicas?
Yes, the caps pop right in. I just got two new replicas to replace two bent wheels. I just popped the caps off the old wheels and onto the new ones.
I had 285's on my other Camaro with replicas and would not go any wider, at least on the front. They pull from side to side more the wider you go, especially on roads that are not perfectly smooth.
9.0=275
9.5.=285
I can't really tell the difference in 275/285 so close..usually the 275 is cheaper and usually 40-80 a set. Plus the 275 would have a smaller sidewall.
Tirerack has all the specs of the sizes of wheels what tires will fit on.
9.5.=285
F'n1996Z28SS
Aug 23, 2023 11:19 PM
stockssn2o
May 25, 2015 08:54 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
