will these fit?
http://cgi.ebay.com/ebaymotors/AFS-9...27748624QQrdZ1
http://cgi.ebay.com/ebaymotors/17-CO...spagenameZWD1V
im thinking about buying these, would these fit on my 94 camaro? what tire size do you suggest?
which auction set of wheels do you suggest out of the two?
Re: will these fit?
The ones in the AFS listing:
The 17x8.5 wheels are listed as +56mm offset/6.95", which means they will fit fine in the front. They will sit fairly deep in the wheel well, moving the outer edge of the tire out about 1/4" farther than the stock 16x8" wheel. You would use a 245/45-17 (25.7") or a 255/45-17 (26.1") tire.
The 18x9.5 wheels are listed as +65mm offset/7.81" backspace. That backspace is going to put the inside edge of the rim very close to the edge of the jounce bumper bracket, and the inner edge of the tire may be close enough to the inner fender to require some hammering. Read the FAQ for details of what **MIGHT** be required. Again, the wheel is fairly deep in the wheel well, with the outside edge of the tire about 0.4" farther out than the stock 16x8's. You would use a 275/35-18 (25.6") or 285/35-18 (25.9").
The Victoria listing:
Only shows 17x8.5" 54mm offset. Basically the same comments as the 17x8.5's mentioned above.
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
