Widest Tires
Wrong forum..... moving to "Wheels and Tires"
You might want to add info regarding the width and offset of the wheels. That info is needed to determine the correct tire size, and whether thay will fit in the wheel wells.
tony
I have the factory wheels from a 2000 Corvette on mine. They are 9.5 inches wide in the rear and I am running 295/35/18s on them. They fit fine. I didn't have to make use of the BFH mod. The axel bump stops keep the tires from hitting the insides of the fender well.
